Service engine soon light
Old May 15, 2008 | 08:59 PM
jhand124's Avatar
jhand124
What would make my SES light not come on anymore with the DP tuner, it still has the power. It used to come on all the time when I got on it or was towing up a hill.
Thanks
Old May 15, 2008 | 09:44 PM
medhvac's Avatar
medhvac
the bulb burnt out is my guess!
Old May 15, 2008 | 09:48 PM
UP_There's Avatar
UP_There
did you adjust any settings on the OBA?
Old May 15, 2008 | 10:41 PM
white Buffalo's Avatar
white Buffalo
IIRC here is why you get the SES light with a chipped truck.
If the ICP indicates pressure fails to reach a specified value, the PCM continues to increase the duty cycle on the IPR until it reaches the maximum of around 60 percent. Somewhere around 50 percent, even if adequate pressure is achieved and the engine runs, the PCM sets a code for ICP above/below normal.
I also have read posts that say the PCM will set the code if the ICP is under 400 psi of the specified value.
The only reason I could see why you do not set the 1211 code is that your engine is able to hold ICP. Have you changed anything recently or since the chip?
Old May 16, 2008 | 12:21 AM
jhand124's Avatar
jhand124
The only thing I have changed is HPX and CCK, but I think it started before that. Kind of weird don't you think, it is an early 99, which should have a harder time with the ICPs. It's an indicator of some thing just not sure what.
Old May 16, 2008 | 01:28 AM
zack7.3's Avatar
zack7.3
Mine quit coming on too. I just figured that I have set it off so many times that the bulb went out.
Old May 16, 2008 | 07:18 PM
jhand124's Avatar
jhand124
That's not it, it will still come on with the turn of the key. There has to be a reason, I'm at a loss.
Old May 17, 2008 | 08:45 AM
Ford79's Avatar
Ford79
I have the same problem(if you want to call it that) with my 01. It used to come on if I even thought of the 140 Extreme setting on the DP. Now it might light the SES light one in every 5 times in the 140 tune. I even used to get it to light up in the 80 Economy tune, not now. I haven't changed anything significant that would cause this either.
It may be time to get a laptop and AE.
Old May 17, 2008 | 08:55 AM
floridadude's Avatar
floridadude
I have an edge juice with attitude and I haven't noticed mine coming on lately either. I've only seen it come when I'm in extreme setting. Kinda weird.
