Front clip removal.
Old May 15, 2008 | 12:36 PM
88CougarCoupe's Avatar
88CougarCoupe
Front clip removal.
Ok so I got a 90 f150 lariat. and need to remove the clip off of it. how many bolts is it to remove the clip and is it hard? I only ask Because I want to throw the 1992 front clip on my truck.
oh and one silly question. how involved is just changing a fender. becausde I only see the two bolts at the top by the cowl and the rest is Sport welded ?
thanks guys. Erik
Old May 19, 2008 | 09:00 PM
lostin90s's Avatar
lostin90s
Everything bolts on fenders to rad support . There is a bolt on bottom fender and possibly one half way up in door jamb(Been awhile) Remove all bolts and hood remove 2 rad support bolts and unplug everything it should come off. Don't forget the cowl off the newer front end *** they r different.
Old May 19, 2008 | 11:02 PM
goodB0Y's Avatar
goodB0Y
I just finished the same (almost it's a F250) conversion last weekend and it wasn't too hard. you'll also need the newer hood hinges...springs are the same, and bumper. I had a hard time with rusty bolts with my swap and had to used the torch for the rad mounts...and I had to fab a new bumper mount and add the extra marker and signal light to the harness, some say to use the newer harness but I found that soldering in the extra lights into the old harness easier than replacing it. have a look in my gallery there are some picts in there of the swap...
good luck,
Corey
Old May 20, 2008 | 02:36 AM
88CougarCoupe
we got the "new clip" off the parts truck. the air gun broke the two fron bolts with the rubber bushings. where can I get these in case I need them on my truck if things get bad. (thinks to self WD-40 mine now!) the oil should help. I'll do it while we strip out the 4 wheel drive out from under it. I'll get some pictures up for you guys. we already had fun with the tourch.!
Frank Murch
Feb 24, 2017 04:39 PM
cru133
Jan 18, 2017 07:31 AM
JeepPuller
Jun 6, 2016 05:56 AM
jpeckham
Sep 19, 2012 12:23 PM
Nitro
Jan 1, 2002 11:46 AM
