67 Front Clip Removal
Nitro
If I remember right, there are 18 bolts holding the clip on:
2 at the front (one on each side of the radiator, through the frame
6 at the firewall (3 on each side; remove the ones that go through
the firewall bracket from the side, and you won't have to adjust
clip height when you put it back on
2 at the rear of the inner fenders (used with an cloth/asbestos
strap from the firewall to eliminate inner fender vibration
4 in the cab near the door hinges (2 on each side)
4 under the rear of the fenders (2 on each side). These tend to be
very rusty; be careful not to tear your cab -- LOTS of WD-40
Don't forget to look for the grounding strap (or wire) that goes from the firewall to the rear of your engine.
Taking the front bumper off also makes the removal much easier.
Eddie
"Keep smiling, it scares the He** out of them."
>Im in the process of pulling the font clip off of my 67 and
>I need to make sure im getting all of the bolts out that
>need to be. I know the ones that go into the firewall come
>out. The ones that hold it to the frame through rubber
>mounts, and the ones that are by the doors going strait up.
>Is there any other bolts i have to pull to get this clip
>off??? Thanks
>Nitro
