front clip removal
Old Sep 15, 2012 | 01:56 PM
jpeckham's Avatar
jpeckham
front clip removal
how hard is it to take the front clip off and swap it for a new one? where are all the bolts located and what all needs to be done?
also, what years and models are bolt ons to replace my front clip with and what the bed?
Old Sep 15, 2012 | 09:01 PM
JayzDaddy's Avatar
JayzDaddy
You need to post your truck info
Old Sep 15, 2012 | 09:10 PM
Franklin2's Avatar
Franklin2
I have never done the complete front clip on one of these trucks, but most American vehicles are the same. There is a bolt down low near the lower front corner of the doors on both sides, a bolt up at the top on each side near the hood hinges, and there are two big body mount bolts up front. There may be a few smaller ones in the wheelwell area.
You need to take the hood off first. And unplug some wiring and hoses.
86-down will swap with no mods. 87-up will swap in, but the lower rear fender bolts are different and need a little bracket made for it to fit. And the 87-up front of the frame is a little different, so the 87-up front bumper will not bolt on correctly on a 86-dwn frame
Old Sep 16, 2012 | 03:12 AM
rbalsinger's Avatar
rbalsinger
Originally Posted by jpeckham
originally i was going to take the front clip off and fix my 86 but the 85 is in better shape so i am thinking about taking the 302 and harness out of my 86 and put in the 85.
Old Sep 16, 2012 | 11:37 AM
jpeckham's Avatar
jpeckham
sorry about that, i have an 86 f150 and found a clip from an 89 i think it is.
Old Sep 16, 2012 | 08:38 PM
Franklin2's Avatar
Franklin2
It will bolt on with the little mod to the lower rear fender bolts. You have to take the whole thing though, it all works together. And watch out for the radiator supports, some of them were different for different radiators.
Old Sep 18, 2012 | 01:55 AM
jpeckham's Avatar
jpeckham
what about the boxes for the different body styles? the box on the 89 is in better shape than my 86.
Old Sep 18, 2012 | 01:58 AM
4x484150's Avatar
4x484150
The box will bolt on. IIRC, the 87+ beds have 6 bolts instead of 8. But they are in the same spots, so youre good to go. When switching, remember about gas fill hoses and wiring.
Old Sep 18, 2012 | 06:27 AM
80FlareSide's Avatar
80FlareSide
I took mine off for the work i did this summer. Aside from breaking a few rusted j-nuts it wasn't very difficult. I just wish that I had done a better job at sorting the small parts into labeled baggies.
The hard part is getting all the body-lines right when you put it all back together. Nearly every hole has either vertical or horizontal adjustment. No matter how many times I adjust, and re-adjust I can not get the hood, fenders and grill to line up as well as I want. Will ultimately probably end up going to a body shop and paying for a few hrs of time to have them do it right.
Old Sep 18, 2012 | 08:34 AM
rbalsinger's Avatar
rbalsinger
Lining up body panels
Are they the original panels or aftermarket?
Old Sep 18, 2012 | 12:02 PM
Franklin2's Avatar
Franklin2
There is a learning curve with lining everything up. And it does take time to do it. And remember quality was not totally job 1 in the 80's, so it may never be perfect.
Old Sep 19, 2012 | 10:46 AM
jpeckham's Avatar
jpeckham
they are original parts
Old Sep 19, 2012 | 12:23 PM
rbalsinger's Avatar
rbalsinger
Check out this video on YouTube:
sunday update and lining up the fenders - YouTube
cowboy.2010
Jul 3, 2018 10:28 AM
twgilbreath
Feb 1, 2013 07:54 PM
MikeS29
Apr 24, 2011 01:21 AM
Josh88Ford
Mar 15, 2010 09:39 PM
TimmyO52
Mar 5, 2010 09:04 PM
