Overdrive button stopped working..... help!
Old May 14, 2008 | 11:57 PM
k2vailkid's Avatar
k2vailkid
Today, I went to tap the OD button to grab 3rd gear, as I often do in this mountainous part of town, , and the OD button suddenly doesn't work. I really need to have access to 3rd gear for EGT's(I've got a slow spooling 1.0 exhaust housing) and instant boost, any ideas as to how one would start troubleshooting this, besides swapping in a ZF6?? Mods are below......
-Kevin
Old May 15, 2008 | 12:04 AM
jhand124's Avatar
jhand124
Most likely the wires is chaffed/broke in the shifter, I replaced the shifter with wires (don't remember the cost) but I have heard there are other ways.
Old May 15, 2008 | 12:24 AM
takotruckin's Avatar
takotruckin
the wire is probably broken down where the shift lever pivots, you could repair it, but the new lever is only like $50 and the wires are real small and hard to splice.
Old May 15, 2008 | 12:25 AM
twags6's Avatar
twags6
Pop the switch out and test it to make sure the switch itself still work. It should slide out of the end of the shift handle. Its a normally open momentary switch. If its bad, Jason has the right idea with the chaffed wires in the shifter handle.
Old May 15, 2008 | 02:59 AM
ron's power stroke's Avatar
ron's power stroke
<TABLE cellSpacing=3 cellPadding=0 border=0><TBODY><TR><TD></TD><TD>ShiftLever.pdf </TD></TR></TBODY></TABLE>
Old May 15, 2008 | 08:16 AM
Pocket's Avatar
Pocket
Off topic:
Kevin are you participating in the live tuning this July?
Old May 15, 2008 | 01:23 PM
k2vailkid's Avatar
k2vailkid
Thanks for the advice about the shift lever everyone, I'll give it a go.
Originally Posted by Pocket
Off topic:
I hope to! Tom sent me an email a little while back, Jody wanted to fit me in, after missing my time block last fall due to that wiring harness replacement disaster at the dealership. I haven't heard back from him yet, but he's always been good at communication.
Seattleslow
Mar 3, 2017 12:22 PM
Ford SD
Nov 22, 2016 04:49 PM
IDIDieselJohn
15
Apr 21, 2015 12:02 AM
peys_daddy08
1978 - 1996 Big Bronco
Dec 27, 2010 11:38 AM
arturohurtado
Jul 24, 2002 10:55 AM
