6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Jumpy in 3rd & 4th
Old May 14, 2008 | 10:30 AM
B-52's Avatar
B-52
Jumpy in 3rd & 4th
I have a 6spd and was wondering if anybody else was having a problem with the truck being real jumpy in 3rd & 4th around 2000 RPM when you are about 1/4 throttle??
It feels like it is not getting fuel for a split second then back on then off etc. It makes the truck lunge back and forth. It does it real bad when I am towing a big load.
Any Advise or anybody else had this issue??
Old May 18, 2008 | 07:26 AM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE, B-52
What is the build date of your truck and have you talked to the dealer technician?
Old May 18, 2008 | 10:33 AM
vloney's Avatar
vloney
Its operator error! Now, before you start, it actually is! There is a reflash that corrects this issue. It starts mostly after you change gears. The slight bump that occurs when you let the clutch out starts it. The weight of the trailer, the clearance between the ball, and the hitch, the deflection of the mounting point of the ball, all contribute. When you have any "surge" it is compounded by the driver foot on the pedal. The seat makes your body move back and forth, causing your foot to do the same on the pedal. The reflash lessens the sensitivity of the "fly by wire" pedal assembly.
Old May 19, 2008 | 09:04 AM
B-52's Avatar
B-52
Yes I have talked to the dealer and techs about it but hard to duplicate with out the trailer hooked up and that is my next step. Truck built April 07
Vloney I hear what you are saying and it makes sense and I thought the same thing but every truck I have ever owned has been a 6spd and I have never had this problem. My 02 would vibrate off the line with a big load but that was the driveline angle. What is the reflash?? Is there a way to lessen the sensitivity of the pedal??
Old May 29, 2008 | 04:07 PM
B-52's Avatar
B-52
Anymore advise?? It does it with a load on or when it is cold. I set the cruise control as to take my foot out of the equation and it still "surges"???
Trying to figure out what this "reflash" is that you are talking about and how to get that done. I have regeared the truck if that is what you are talking about. I have 37" tires with 4;56 gears.
Any Ideas??
Vegas Ernie
Aug 25, 2010 07:36 AM
owen.25
Dec 9, 2008 12:25 PM
crazyrwe
Modular V10 (6.8l)
Sep 23, 2006 10:33 PM
K2JJB
Aug 21, 2006 08:14 AM
tex_26
Apr 5, 2002 01:54 PM
