Thread pitch and Diameter Question
Old May 13, 2008 | 01:51 PM
csangster's Avatar
csangster
What is the thread pitch and diameter of the coolant plug on the passenger side of the 7.3 IDI? My model year is 94.
I would like to make a fitting so I can drain my coolant without making such a mess.
Thanks,
Chris
Old May 13, 2008 | 09:17 PM
catfish101's Avatar
catfish101
It is going to be a pipe thread. Probably 3/8 or 1/2.
If it a SAE thread it will have a o-ring seal. You don't see that much on engines because most sensors or switches are a pipe thread. Rarely will you see that, basically, because of the added machine work on the engine casting to be able to use an SAE or Metric thread plug or sensor.
Old May 13, 2008 | 09:55 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Standard pipe thread.
I can't remember, I think it may be 1/4" pipe thread.
You should be able to get a block drain at an auto parts store that will thread right in.
Catfish has me wondering now, may be 3/8" pipe thread, I know it is not 1/2" though.
Old May 14, 2008 | 01:50 PM
northern 7.3's Avatar
northern 7.3
Temporarily Deactivated
not standard, thats british. its NPT, national pipe tapered thread. t stands for taper not thread
Old May 14, 2008 | 03:38 PM
tbone91's Avatar
tbone91
NPT = "National Pipe Thread Tapered"
The term "pipe thread" is slang for NPT.
There's "standard" and there's "metric" and then there's "Canadian"
Sorry, I couldn't resist!!! ...
In the US 1/4" NPT specifies diameter, pitch, and taper (0.540", 18, 0.05556). There's no ambiguity and it is a standard. The entire world may not use it, but it's still a standard.
Old May 14, 2008 | 11:05 PM
ford trans tech's Avatar
ford trans tech
1/4 npt on the right side
Old May 15, 2008 | 08:25 AM
csangster's Avatar
csangster
1/4 Npt
That sounds easy enough for me to make a fitting that will help me drain my system.
Thanks to all,
Chris
Old May 15, 2008 | 01:14 PM
northern 7.3
Thats ok man, jealousy will get you nowhere.
Old May 15, 2008 | 03:23 PM
tbone91's Avatar
tbone91
If only it wasn't soooo cold there, I'd move in a second -- I spent enough time in Toronto to find a new bride...
Probably the most amusing thing I saw there was a couple of young guys laying carpet. They had a tape measure marked in both inches and meters, and were calling out measurements in inches. When I ribbed them about it, they got nervous and started calling out metric.
Rollin.IH.Coal
Jun 22, 2013 08:47 AM
RRRAVEN
Nov 17, 2010 01:48 PM
currituckF150
21
Feb 1, 2010 10:06 PM
scotjonscot
Jul 14, 2009 05:19 PM
