Which bolt are you talking about? The 1 in the front of the rad arm on top or bottom?
It's 2" long 3/4" diameter and 10 threads per inch. Hope this helps. Oh yeah and you know the one on top has a stud off the back to hold the spring right.
Just in case its the axle pivot bolt, for a 4wd, I used grade 8 9/16 x 4 coarse thread. You should buy a new nut anyway, so just match the nut to the bolt.
Yes, those are the ones. Really just the upper one that holds the spring.
