1988 EFI 5.8 liter performance problems
Old Jul 27, 1999 | 05:49 PM
ArturoPadilla's Avatar
ArturoPadilla
Rebuild engine has 20K miles. Started noticing accerlation problem at high speed (55-70 mph) when going up hill, passing cars, etc. Had fuel system cleaned and engine tuned up with no great improvement. Tune-up shop suggested compression check, all cyclinders running between 125-140 psi. Now engine is starting to ping and wants to make a funny back-fire type of noise when accerlating from a stop. Plug wires are new and have been verified going to correct plugs. I have a code scanner but computer reports no error codes. How does a person check the fuel injectors?? Somewhere on this bulletin board I read something about a propane vaccum leak check on the intake manifold. How is this done?? Does anybody have any suggestions or might have come accross the same problem. I hate to take the truck to a dealer and get surprised with a $800-$1000 bill if I can do the job myself.
Thanks in advance for any help.
Art Padilla
Old Jul 30, 1999 | 10:49 AM
slik's Avatar
slik
Sounds like it could be a timing problem. Check the timing, check the vacuum advance, and it even could be the timing chain getting worn and sloppy; but check your timing first.
Slik
Old Aug 8, 1999 | 07:53 AM
jedison's Avatar
jedison
77f2504by4
15
Oct 31, 2021 03:07 PM
obsjoe
Feb 9, 2016 03:52 PM
jaskracing
Aug 3, 2015 08:30 PM
BMcT
13
Oct 7, 2014 06:54 AM
Joe Mac
Mar 16, 2003 11:26 AM
