Do I need a locking gas cap?
Old May 13, 2008 | 03:59 PM
rangersvt04's Avatar
rangersvt04
i have a locking gas cap and its paid for its self. last year living in the dorms (gas was about $2.20) my friend and i walked out to the parking lot, discovered every truck and suv had its fill door open and gas caps off with empty tanks!!!! my friends ranger was empty the day before so we were gonna take my ranger to school.. well i had a full tank and NONE of my gas has been stolen i give the credit to the locking cap.
just last week my neighbor had 30 something gal stolen out of his 07 hemi ram! he has a locking gas cap and a new Dimond plate skid plate around his tank! poor guy was leaving for Florida that day and had filled his tank the night before.
As far as the keeping the key for my cap.. 1 of them is on my key ring and a copy is in my truck just not in the cab, i have it wired to the inside of the steak pocket.
Old May 13, 2008 | 09:23 PM
Dad's Truck's Avatar
Dad's Truck
God help anyone I catch stealing my gasoline...
Old May 14, 2008 | 01:16 AM
mfp4073's Avatar
mfp4073
has it really become The Road Warrior?
Old May 14, 2008 | 04:26 AM
Pablo-UA's Avatar
Pablo-UA
YouTube - Mad Max 2: The Road Warrior subtitulada en castellano (1)
Mad Max is back
Old May 14, 2008 | 09:08 AM
jason867's Avatar
jason867
If you do get a locking gas cap, I recommend getting a certain type.
My 1978 truck has locking caps for both tanks (even though there's only fumes there most of the time, lol). Anyways, they're made of metal and they have little tabs that stick out and catch the ring of the filler tube. Very secure.
I just bought a locking gas cap for my little ranger, and I'm not nearly as impressed. Basically when you "lock" it, the top half of the cap spins freely from the bottom half. When you "unlock" it, it turns as a whole and allows you to tighten/un-tighten it.
The problem is, when it's locked and turns freely, if you pull out on it while turning, it grips the bottom half enough to actually turn it loose... It's still a decent deterrent, but if a thief spends a little time with it, they'll likely get it loose...
P.S. There had better not be any theifs on here...
Old May 14, 2008 | 09:31 AM
pintoches's Avatar
pintoches
Originally Posted by sfcwoodret
I would get one if you live in the city or immediate rural areas. I wouldn't bother if you live way out in the country as myself.
MY lake house is about 25 miles it to the country that did not help Some one drained my 76 and 68 last summer in the same night, got the tracker next door to! (15 miles out to the gas staion) So I left a new full 5 gal gas can next to the 68 the next night (lb of sugar in it) Two of cars at the crack house down the street don't run any more
Old May 14, 2008 | 12:24 PM
racsan's Avatar
racsan
i know the locking caps where the top half spins while unlocked are easy to defeat, i borrowed a freinds vehicle once and had to put fuel in it, didnt have the key, but found a drywall screw in the cab and a screwdriver. easily went through the plastic and locked the top of the cap to the bottom. most locks merly keep a honest man honest and only slow the true theif a little. ive thought about some sort of a cabinet lock that would keep the fuel-filler door shut, kind of like what toyota had at one point in time. (dont know if they still use it or not)
Old May 14, 2008 | 12:33 PM
pawpaw's Avatar
pawpaw
My 94 Taurus has a locking fuel filler door, you'd think the dinks at Ford would have added one to the Ranger by now!!!????
Yup a locking fuel filler door or gas cap won't deter a pro, but will likely inconvience a kid, or someone in a hurry bad enough for them to move on to easier pickings.
Old May 14, 2008 | 01:12 PM
Pablo-UA's Avatar
Pablo-UA
Look, ranger has anty-sipon in tank filling neck, but to steal thief can remove filling hose and do it with thin hose. To steal throught filling door is nearly impossible, especially if tank is not full.
Our drivers to make gas/disesl thiefing difficult put gauze below anty-siphon. They remove fuel sender and do it from inside tank. But... thief can drill hole!
Old May 14, 2008 | 01:57 PM
Bikeitswift's Avatar
Bikeitswift
So, how did they get it from the Hemi?
Old May 14, 2008 | 02:12 PM
Pablo-UA's Avatar
Pablo-UA
__________________________________
There ia one hypotesa
Old May 14, 2008 | 03:34 PM
Pablo-UA's Avatar
Pablo-UA
Look under any truck and you will see how easy to remove hose and steal gas throught filling neck. No lock helps. Of course you can install metal plates to deny access to filling neck.
but... some exotics. My friend has Opel Vectra-C known in the USA as Saturn Aura with 3.5 DOHC.
Thiefs open hood (how? nothing is brocken), disconnected fuel line, short fuel pump relay and did all with fuel pump. No drop of gas in tank. Absolutelly empty. Engine did not srart!!!
Old May 14, 2008 | 06:03 PM
  #28
pawpaw's Avatar
pawpaw
Pablo, on my old 78 Mercury Zypher & Toyotas, you could lay on your back, under the front of the vehicle & using wire hook fashioned from a coat hanger, hook & release the hood latch very quickly & easily, so I imagine thats how they got the hood open without breaking anything.
Probably wouldn't be very difficult to open a locked fuel door that way either!!!!
Old May 14, 2008 | 11:30 PM
  #29
Pablo-UA's Avatar
Pablo-UA
__________________________________________________ __________________
Aura fuel tank is located under rear seat and it is really imposible to siphon fuel out. Fuel door is locked with central locking system. Very difficult to open.... but thiefs found another way.
jsw0767
Oct 14, 2014 06:06 AM
kabur66
6.7L Power Stroke Diesel
68
Mar 15, 2012 04:50 PM
Wedgehead
2009 - 2014 F150
Oct 11, 2011 07:02 AM
walt460
21
Jan 1, 2009 09:03 PM
