302 compression
Old Apr 19, 2000 | 07:24 AM
RockyBhm's Avatar
RockyBhm
302 compression
Hi folks, 94 F150 5.0. Just had the engine evaluated. All cylinders 125 - 130 lbs, oil pressure 30 - 35lbs. Truck has 161000 miles. How do these numbers compare to new.
Old Apr 23, 2000 | 09:06 PM
jamden's Avatar
jamden
302 compression
My Haynes does not give a compression pressure listing just says "lowest cylinder must be at least 75% of highest cylinder". Oil pressure at 2000 rpm normal operating temperature should be 40 to 60 psi. I had my 1992 F150 Supercab SB 4x4 with 53k miles checked 2 months ago. Compression was 140 to 150, oil pressure at idle was 60 psi.
Old Apr 26, 2000 | 11:53 AM
Pastmaster's Avatar
Pastmaster
302 compression
underthebridgejim
Jun 15, 2015 11:47 PM
kbf1961
Jun 15, 2015 03:50 AM
BryanStein
Nov 3, 2014 06:56 PM
McMurray#1
Oct 17, 2014 10:08 AM
relayman53
May 21, 2014 05:44 PM
