slow cranking at start
Old May 12, 2008 | 12:05 AM
jcab's Avatar
jcab
Well it's been along time, but I would appreciate some thoughts on this one. I replaced the glow plugs, relay, batteries are fine, alternator is fine. Could it be the starter causing condition where it sound like batteries are low? Thanks Jcab
Old May 12, 2008 | 12:08 AM
jcab's Avatar
jcab
I forgot to tell everyone it is a 97 f250 diesel and battery termnals have been cleaned. Thanks again Jcab
Old May 12, 2008 | 01:20 AM
WALJON's Avatar
WALJON
Sounds like the starter if you are certain the batteries are good.
maybe get your batteries load checked to make sure they are truly good.
Old May 12, 2008 | 01:59 AM
kawa's Avatar
kawa
2X what WALJON said.
Rog
Old May 12, 2008 | 10:29 AM
Neal 97 250's Avatar
Neal 97 250
10-4 The starter can definately show those signs. If you remove it the parts stores can bench test it for you. I also agree a load test on the batteries is a good idea but they have to be done independant of each other.
Old May 12, 2008 | 11:11 PM
jcab's Avatar
jcab
Thanks for the replies. Can autozone load test them, they checked them the first time. And I will check the starter. Jcab
Old May 12, 2008 | 11:23 PM
secondarychaos's Avatar
secondarychaos
Yes autozone can usually check them for free, and they can also check a starter motor for how well it works. pretty sweet setup.
Same bench can test alternators.
Check all your wires on the way to the starter for a bad connection/short/grounding. that's a fat chance, but if you're running out of options, thats something to look at.
Old May 13, 2008 | 06:47 AM
Neal 97 250
Alot of times autozone and advance want to test the batteries together. Make them test them separately so you can isolate the bad one if there is one.
Old May 13, 2008 | 12:50 PM
secondarychaos
might there be a problem with one dragging the other down???
Old May 13, 2008 | 01:21 PM
Neal 97 250
Possibly, or the good one is hiding the the fact that the other is bad. ie: the good one supports the load whereas the other one couldn't by itself.
