1966 - 1977 Early Broncos
V.I.N. decoder problem...1982 - present!!
Old May 11, 2008 | 08:20 AM
gvrangr98's Avatar
gvrangr98
Arrow V.I.N. decoder problem...1982 - present!!
ok guys and/or gals...all the VIN decoder sites(even Ford) won't decode anything older than 1982! I think i've looked every where. can some one point me in the right direction? Or can you decode this V.I.N.....
This is how it reads on the metal stamp on the inside cover of my glove box...
U15GLE93312
092 H U150 9U98 C B8J
51
as you can see there are a few different #'s. a vin is supossed to be 17 digits, right? Well the bottom # is 16, unless you add the 5 and the 1 that's two to many. maybe it was different before 1982!? Help me out here guys. Thanks.
Old May 11, 2008 | 10:15 AM
1975StroppeBaja's Avatar
1975StroppeBaja
Originally Posted by gvrangr98
U15GLE93312
51
A good VIN decoder for Early Broncos can be found at
http://www.broncohio.com/tech/ebvins.html
Click on the tabs at the bottom for the different years.
From your VIN U15GLE93312
U15 - Bronco with full top
G - 302 V8 engine
L - built at the Michigan truck plant
E93312 - 1969 model year, built in March
From the other numbers 092 H U150 9U98 C B8J 51
092 - 92" wheelbase
H - color code that isn't on the list, maybe its an N?
U150 - 3900 lb GVW package
9U98 - not sure about this one?
C - 3 speed manual transmission
B8J - B8 is 3.50LS 2780# rear end, not sure about the J?
51 - DSO code for Denver, CO
Old May 11, 2008 | 03:17 PM
RCrawler's Avatar
RCrawler
The 9U98 is the body and trim code.
98 is for long roof (wagon) or HD wagon. In this case, it would be the standard U150. I think that 9U is for parchment interior, maybe for the Sport package. This is the same code as my 69.
A "J" along with the axle code denotes power steering. But since it wasn't offered until 73, it doesn't make much sense.
Jason
apfeifer11
Large Truck
Jul 20, 2020 07:46 PM
Purplepills
Sep 17, 2015 11:15 AM
MikeB 88
1983 - 2012 Ranger & B-Series
Aug 21, 2014 06:00 PM
huckster
Jul 20, 2003 10:09 PM
phineast
May 28, 2001 12:09 PM
