stupid 302
Old Jul 21, 2000 | 03:16 PM
slikness's Avatar
slikness
stupid 302
Old Jul 22, 2000 | 10:31 PM
bluebomber's Avatar
bluebomber
stupid 302
my 302 is toast i think unless theres something that can be done about it i know it has something to do with my driving but i cant help it i always have it held to the floor boards always lighting the rear tire up stuff like that. the problem is that when i come to a stop it loses all oil pressure when i get going again the needle will go back up to the r or the m in normal and it will continue to do this every time i stop.it runs fine when it has no oil pressure and ive let it run for a while when its like that. any help here guys?
the truck has about 192000 kilometers on it
its an 89 f150
Old Jul 23, 2000 | 12:01 PM
windsor's Avatar
windsor
stupid 302
Get a manual oil pressure guage and remove your oil sending unit and check to see what the pressure is at hot and cold,low and high idle.The pressure should be around 25-40psi.The pressure will be higher when cold.This will tell you if its a guage problem.Since its a high mileage and often abused engine,your probably going to have to put rod and main bearings in it.These are the crankshaft bearings and their clearances are getting wider.This is a very time consuming job.I have done it a few times and you dont have to pull the engine,unless you want to overhaul it. You have to jack up engine,drop exhaust,drop oil pan and oil pump and then remove a couple of caps at a time and DONT get them mixed up!!!They are numbered on the sides.And you could overhaul it,but if you're strapped for cash new bearings and new oil pump(since its out)is a lot cheaper. The new bearings will decrease the amount of clearance between the crank and rod journals,thus increasing your oil pressure.Good luck Windsor
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
