How did i go wrong?
Old May 10, 2008 | 07:12 PM
Benny2002's Avatar
Benny2002
Question How did i go wrong?
Did koolaid mod today. There are so many threads and opinions on how to do the flush its beyond me how i went wrong. Flushed twice with tap water, twice with distilled water and the last flush let drain for an hour. Pulled the plugs both times with distilled. Truck was on flat ground. Put in the 203 thermostat, new neck. No leaks let truck idle for probably 20mins after putting in koolaid hoping the level would drop but it didnt.
Problem truck only took back a little over 6 gallons of coolant, seems im about a gallon short?
Air? Water? Drive it for a few days and it will go down?
Any thoughts or exp? thx Ben
Old May 10, 2008 | 08:04 PM
rebelchevy02's Avatar
rebelchevy02
When i did that on my truck, (flush with water, run it, then change water pump, stat, etc) I could only get just over 6 gallons in mine aswell. I even used compressed air to flush out most the heater coil. It was in the shop, so on level ground aswell, and well, the water pump was off lol. But thats all my truck took aswell. Its also an 02, if it makes any difference with these trucks.
Old May 10, 2008 | 08:37 PM
Benny2002's Avatar
Benny2002
Thanks mike im glad im not alone, should i just forget about it and add the 50/50 as i need it?
Old May 10, 2008 | 09:03 PM
rebelchevy02
I would, I just look at the resovoir when I do my underhood inspection to check the oil etc. But if youve already had it up to temp, a time or two, and added as needed, it probably wont drop anymore.
Old May 10, 2008 | 10:43 PM
ron's power stroke's Avatar
ron's power stroke
the heater holds some as well..not sure on the exact amount...maybe a gal. or 2
Old May 10, 2008 | 11:15 PM
clux's Avatar
clux
What ron said, did you run the heater?
Mine will only hold a little under 7 gallons.
AMG-SM
29
Sep 9, 2019 11:47 AM
ManfredVonRichtofen
1978 - 1996 Big Bronco
28
Aug 9, 2013 12:27 PM
greentree ford
Nov 15, 2012 04:24 PM
frenchy750
Jan 20, 2011 04:13 PM
dirtriderdan
Nov 23, 2009 09:30 AM
