The forward slope or stepped neck is to keep the trailer out of the trucks rear window on the shortbed trucks. Without some kind of offset, on a sharp turn like you sometimes get when backing the trailer corner will remove the pickup's rear window on the shortbeds. This is a design that is more common now then it used to be.
It also allows the trailer to be connected to the tube at a lower point which reduces leverage and extends the life by reducing fatigue cracks.
That is what I had assumed as well, but after discussing this with a local trailer manufacturer I found it is more looks than anything. I was discussing changing my big g/n that has a straight neck. The owner told me it was a waste of money and no need. I must say I do like the looks of the angled fronts better.
Thanks for the replies.
I found this at H&H Trailers:
"Our standard gooseneck drop down nose eliminates excessive coupler flex under heavy load…this eliminates that ‘jerking’ sensation you’ve felt from the drivers seat with other trailers."
Interesting I had to look at the pic to see exactly what you meant. Around here a slopped end like that is rather rare and I can't say I've ever pulled one. Is an interesting comment on the jerking I always thought it was a combo of the load position and road condition.
Hmm, most of the flatbeds (especially the newer ones) I've been around are like that...
