Help IDing drive train
Old May 9, 2008 | 08:32 PM
OldMetal's Avatar
OldMetal
I was wondering if anyone could help me here and tell me what I have in my 77 F150 4X4.
The numbers on the frt axle are: ED D7TA-ANA 603808-9-3-50 also if you know the part# for the wheel bearing socket I would love you forever
The rear axle number is; WDM-AE2 7AD 3 50 9 379A.
The only numbers I see on the trans are C-96391 with AH below that and F01 elsewhere with 10-76 below it.
I can't find any numbers on the cast iron T-case??
This is the best I can read all the numbers so I hope they are all correct.
Thanks guys.
Old May 9, 2008 | 09:17 PM
RJR99SS's Avatar
RJR99SS
well i'm pretty sure the front axle is going to be a dana 44 no matter what. is the rear axle semi-float or full float? If it's semi it'd be a 9", if it's full floating (big hubs going through the rear tires, 8 lug) then it's a dana 60. Is the trans auto or manual? If it's manual, if it has an aluminum shift cover it's an np435, if it's an iron shift cover it's a t-18. The transfer case is probably a np205, if you have lockout hubs on the front then thats what it is.
Old May 9, 2008 | 10:27 PM
RCrawler's Avatar
RCrawler
An F150 will have a Dana 44 in the front. Uses a OTC #7157 socket.
Jason
Old May 10, 2008 | 06:45 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D7TA-ANA / Dana 44-7F / 3.50-1 / Free Running Hubs / non Limited Slip / 3500 lbs. Front Axle Capacity.
WDM-AE2 / Ford 9" / 3.50-1 / non Limited Slip / 31 Spline Axleshafts / 3300 Rear Axle Capacity
Old May 10, 2008 | 07:15 AM
LxMan1's Avatar
LxMan1
No LS? Makes it a 2wd is slippery stuff EH???
Old May 10, 2008 | 07:37 AM
80broncoman's Avatar
80broncoman
In my Time behind the wheel , after So many miles most clutch plate limmited slip become UNlimmited slip diffs. (Unlimmited = same as a Open)
Old May 11, 2008 | 01:50 PM
OldMetal's Avatar
OldMetal
Thanks guys, what can you tell me about the cast iron T-case? All I know is that it looks smaller than a aluminum case and uses 90w oil. Is it chain or gear driven ect...?
Old May 11, 2008 | 02:53 PM
RCrawler's Avatar
RCrawler
On the back of a 205, there is a round 3 bolt cover, approx 2 1/2" diameter. This is the part time gear driven transfer case
A 203 has an aluminum rear output housing. Originally they came as full time version, but many have been converted with available kits. They are chain driven.
Jason
lbrauer
Nov 19, 2023 01:50 PM
lbrauer
Projects
Jun 17, 2016 03:34 PM
ethand320
Apr 24, 2014 06:14 PM
sonny1965
Apr 17, 2014 04:26 PM
wyazel1
27
Jul 7, 2012 07:19 PM
