Help With Identification
Old Apr 24, 2016 | 10:18 PM
lbrauer's Avatar
lbrauer
Hey guys I have searched the forum and still can't find what kind of engine I have so I can get some parts to rebuild. I thought it was a 1975 302 but when I ordered the crankshaft bearings the front main bearing is not wide enough nor is the little lip (tit) on the side like all the others it is in the middle of the bearing. The following below is all of the numbers I can find on the block.
MS590P 12-590P
4L20 E8AB C3B
and on the engine block top covered by the intake these numbers are stamped
F or EKA51393
Do any of these numbers mean anything and if they do can you tell me what is the cubic inch and what make it is.
Thanks in advance for the information,
Old Apr 25, 2016 | 09:08 AM
Conanski's Avatar
Conanski
Post up some pictures of the block. If I'm reading those numbers right it appears to be an '80s block which would eliminate most of Fords older engine families, but there is nothing in the engineering numbers to ID engine family.. that has to be done visually.
Old Nov 19, 2023 | 01:50 PM
Peter2's Avatar
Peter2
1st Gear
Question Fred Jones rebuilt 6 cylinder
I have a Fred Jones rebuilt 6 cylinder
939606
C52TZC
Is it a 300 6 cylinder or 240 6 cylinder?
lbrauer
General Automotive Discussion
Apr 25, 2016 05:21 AM
lbrauer
Apr 24, 2016 12:18 PM
lavcheech
May 21, 2005 02:56 PM
Chugalug
Mar 22, 2005 04:00 PM
