Durespark Conversion
Old May 9, 2008 | 02:35 PM
jim2029's Avatar
jim2029
I have a dist., coil, and ing mod. out of an early 80 truck for my 86. I ahve looked but found nothing about wiring it up for the colors i have.
Coil:
Red
Green
Dist:
Purple
Orange
Black
Mod:
Red/Blue strip
While/Blue dotted strip
Purple
Light Orange
Tealish green
Black/Green dotted
How do I wire this thing up?
Thanks
Old May 9, 2008 | 03:26 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Maybe you should just get the blue grommet DS box that goes with that setup?
Does this help?
Duraspark II
Old May 9, 2008 | 04:35 PM
jim2029's Avatar
jim2029
that helped but i'm getting no spark. I noticed that a ballast resister is needed after the coil. I used an extsting one that was on my factory harness.... a green wire with a brown box thing on it. I ahve everything wired.... so I think the mod i got at the junk yard was bad.
Old May 9, 2008 | 06:57 PM
Franklin2's Avatar
Franklin2
Old May 9, 2008 | 09:21 PM
jim2029's Avatar
jim2029
that diagram ^ also helped alot but I still am not getting any spark. i had the modgual tested and its good. If i can't get this to work i'll just scrap the thing and buy me a chevy as I have never had any luck with fords.
any last ideas???
Thanks for all of you guy's help....
Jim
Old May 9, 2008 | 09:24 PM
Franklin2's Avatar
Franklin2
Do you have voltage on the coil +?
Do you have voltage on the red wire to the module?(I believe this will hook to the blue/white wire from the harness).
Do you have the black wire hooked up to the dist? This is the only ground for the whole system.
Old May 9, 2008 | 09:32 PM
jim2029's Avatar
jim2029
Not sure, Yes, Yes.
I am still useing the square coil. Is that ok? I thought I'd be better as I just bought it 3 days ago. I have the round one but I have no center wire for it as I didn't relise it was different connector on it when I was at the junk yard today.
Also, I ahve a new GM Modgual from a 93 chevy with a 4.3 and I have used these in 350's... Can this be used if i can't get the duraspark box working? It has 2 pins sticking out saying P and N. There the small plug has a +C and the larger plug has a GMRE... Just an idea.
Thanks
Old May 9, 2008 | 09:57 PM
jim2029's Avatar
jim2029
No power to the coil. I ahve a blassest resister between the + on the coil and the battery (I'm direct wiring it to the battery to test this to see how it will work before wiring it in permint).
Old May 9, 2008 | 10:28 PM
jim2029's Avatar
jim2029
I removed the ballast resisiter and now I have power to the coil. But still no spark... I'm out of ideas....
Old May 9, 2008 | 10:42 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I assume the distributor is turning.
Either the box is bad or the pickup in the distributor is bad.
I get like 660 Ohms across my pickup.
*edit*
Another thought, you're going to cook your coil if you leave it hooked up w/o a resistor......
Old May 10, 2008 | 10:47 AM
jim2029's Avatar
jim2029
Well, I'm done. Its going to the scrap yard. I have sunk too much money into it in the last 2 weeks. It was my grandpa's old truck and I got it when he died so no one knew what was really wrong with it. It's like "The Money Pit".
Thanks.
Jim
Old May 10, 2008 | 10:51 AM
IcemanV8's Avatar
IcemanV8
Not knocking anyone, but it just needs someone who knows more about it to look at it. Wouldn't scrap a good truck over not being able to solve a small problem.
Old May 10, 2008 | 05:31 PM
jim2029's Avatar
jim2029
well... I could not get it timmed and all i heard was how converting it to a duraspark system would fix everything.... and its not. Now it wont even run and I have wired it too many time to count, bought 5 ballast resisters so I know I can't have a bad one.... I'm just tired of it. Its a 22yr old truck and its rusty... I had not planned spending $500.00 in parts and not being able to drive it. I could have gottin my old dodge back on the road for that.
Old May 10, 2008 | 09:13 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
There's really only five things that will cause a no spark condition on the Duraspark II.
1) Bad Module, but you say your module is good.
2) Bad Coil, + if in doubt put a new one on it.
3) Magnetic Pickup in the distributor. This as far as I can tell you have not checked.
4) Bad wiring. Double check the wiring. A bad resistor can be checked easily with a mutimeter.
5) Bad Ignition Switch,
Test one thing at a time, and totally eliminate that section first, then go to the next.
Old May 10, 2008 | 09:19 PM
81-F-150-Explorer
Thias does not sound right to me.
The resistor Wire should be color Red/Lt. Green stripe. The same color as the coil wire from the ignition switch.
