Sponsored by: Real Truck
Message center-TBC
Old May 9, 2008 | 11:23 AM
JS-SD's Avatar
JS-SD
Message center-TBC
On 2008 Ford F250 SD with TBC system should I being seeing a readout in the message center on the dash for the TBC setting? It indicates "TBC = 0.0. I manual set the TBC to again of 8.0 which seems high for my 30 ft trailer and I have the green icon indicating the trailer is connected. By manually operating the TBC the trailer brakes work but I cannot tell if they work using the truck brakes. My dealer doesn't know either.
I really like the Tow/Haul command system.
Old May 9, 2008 | 05:01 PM
ReAX's Avatar
ReAX
The brake system runs off voltage, so put a test light on the brake wire at the trailer and have someone step on the brake. Or I am usually alone when doing diag, so a block/brick or a right sized 2x4 can depress the brake pedal for you.
lakewood
Nov 14, 2012 09:41 AM
Ford Fx4
2009 - 2014 F150
39
Mar 28, 2012 09:15 PM
danosll
Jun 17, 2011 10:24 AM
caprang
6.4L Power Stroke Diesel
13
Jul 3, 2008 06:18 AM
caprang
Jul 1, 2008 09:34 AM
