fuel injector cleaning
Old May 9, 2008 | 10:20 AM
geraldo14's Avatar
geraldo14
Hey guys,
I have a 94 F250 5.8 liter with 96K miles. Can I remove the fuel rail and clean or replace the filter that is placed at the top of the fuel injector? Has anyone done this? any suggestions or opinions are greatly appreciated.
Jerry
Old May 10, 2008 | 07:25 AM
LxMan1's Avatar
LxMan1
I've never had to. My Mustang injectors have about 163K on them and have never been cleaned.
Old May 13, 2008 | 09:57 AM
geraldo14's Avatar
geraldo14
this truck sat for a long time, I changed out the inline fuel filter on the frame rail. I put in a full tank of gas and the engine will drop out as if I turned the ignition off for a second. I've even replaced the TPS, plugs, wires, cap and rotor.
Old May 14, 2008 | 08:35 PM
LxMan1's Avatar
LxMan1
Sounds more like an ignition problem.
Old May 15, 2008 | 08:23 AM
geraldo14's Avatar
geraldo14
problem
Thanks for the reply, I even replaced the coil, a person here had mentioned that his bronco did this and he replaced the coil and the problem went away, I hooked up an OBD1 code reader and recieved no Trouble Codes, I don't know what to try next.
Jerry
Old May 17, 2008 | 06:36 PM
LxMan1's Avatar
LxMan1
I was thinking more like the ignition switch under the column or the ignition module.
Old May 18, 2008 | 10:30 AM
geraldo14's Avatar
geraldo14
thanks
I'll give that a try next, thanks again for the help
Jerry
Old May 18, 2008 | 01:24 PM
boatmoter's Avatar
boatmoter
you might wanna try putting a timing light on it and watching the light to see if it stops flashing just when the engine cuts out,and put a fuel pressure tester on it and watch it also.. I have run across several times on customers cars that when they sit, rats sometimes make it their home under the hood and chew on a few wires also.
Old May 20, 2008 | 08:56 AM
geraldo14's Avatar
geraldo14
suggestions
Thanks for responding, I'll try your suggestions, I appreciate the help.
Jerry
Old May 20, 2008 | 10:26 AM
Conanski's Avatar
Conanski
Gas starts to gel pretty quickly these days, I know if I don't use fuel stabilizer when storing motorcycles I have problems with clogged low speed ports in the carbs the next spring. I can immaging fuel injectors would suffer similarly. Best results are usually obtained when the injectors are completely removed from the vehicle and serviced by an injector shop, this usually involves new filters and seals, and cycling the injectors with cleaning products until the proper spray pattern is obtained. That said I have seen several sites with DIY injector cleaning procedures on the web, one in particular looked like it got pretty good results. The injectors were removed from the vehicle, filters and O-rings removed from the injectors, and then they were soaked in carb cleaner for a period of time. Then compressed air is forced through the injector while it is electically activated, and they were reinstalled with new filters and O-rings.
Old May 20, 2008 | 11:59 AM
geraldo14's Avatar
geraldo14
fuel/Injectors
Thanks for responding and your suggestions. I've taken fuel rails and injectors out before, maybe I can remove them and then take them to a shop.
Jerry
BocceMon
Apr 20, 2016 03:16 PM
Renneberg
Aug 3, 2014 10:47 AM
PeterTheWolf
2004 - 2008 F150
Apr 26, 2012 03:57 PM
jetmech1999
Aug 27, 2004 02:57 PM
austinpower
3.8 & 4.2L V6
Dec 18, 2003 10:38 PM
