Weak 289/302
I have a 1984 Ford Bronco XLT with a 1967 289 with 78 302 Heads, 302 2 Barrel Intake, 2 Barrel Carb, 3 Speed Manual Transmission with OD (4th Gear).
I just bought this Bronco from a friend, the engine is practically brand new. (Less than 3000 miles on the engine) The problem is this. He wanted to have good gas mileage when he built the engine, but I think he over did it. He had a NAPA Economy Cam installed, and put on a 2 BRL Carb. I have a factory 4 BRL 302 Cast iron intake, and a Holley 600 CFM 4 BRL Carb for the truck. Now here is the thing. This 1967 vintage 289 engine when it was rebuilt was bored 30 over, and had flat top pistons installed. Also of note is there is an electronic distributor out of a 78 302 installed in this engine. I want to put a more agressive cam in the engine and install the 4 BRL intake and Carb. The problem is with the engine being peiced together as it has been what Cam do I need? I mean intake and exhaust duration? The engine runs very good but has no power whatsoever on the top end. Low End is fairly good, not impressive but decent. I want to get this thing going a little without killing drivability. I was thinking about going toward a stock grind cam for a 289 4 BRL, but with the 78 302 Heads and the Flat Top pistons I just dont know. What grinds can I use with out throwing the valves into the pistons? Any help you guys could give would be appreciated.
THANKS!!!
the older 289/302's, were not real torquey.
the other thing to check before doing anything is to see if you are getting any spark advance.
the ignition systems from 78 to 84 are different and use different spark advance methods, so you might not be getting optimum high end performance.
good luck and do your homework before you spend your dough!!
Those '78 302 heads hurt you on the top end.. small valves and poor flow characteristics.. you are deep into the emmission heads by that year... so no matter what you do with a cam and intake changes you are not gonna get much out of the top end..
hope this helps....
Bill in Mobile
'64 F100 Shortbox ('70 351W/'76 C4)
>about that. The guy I
>bought the truck from has
>289 HiPo heads. Problem is
>he said if I stick
>those on its gonna send
>the compression through the roof
>and I would have to
>goto the airport for fuel.
>Ugghhh, This sucks.
Maybe not! I say, if the HIPO heads are in good shape, it will only cost you a "valve grind" gasket kit to find out if they are acceptable. Also, an RV cam, as already suggested, might allow you to advance the timing enough to eliminate spark knock. I would try them, that motor should really run with those heads!
Nathan
You know? It doesn't have enough b@11s to turn that big of tires right now. LOLTrending Topics
Pastmaster's 1993 XLT 5.0 E40d 3.55LS Normal Cab/Long bed Loaded from the factory with aid of...MSd 6a ign/s.p. wires, blaster coil, Hypertech Chip, K&N filtercharger, Cat-back dual exhuast w/o mufflers, 3.5", echo tips, Accel distributor cap, Dark Mocha over light mocha. 5% Dark tint, Alpine Cd player/remote, Pioneer speakers.
>regearing. How much would that
>cost?
A professional job w/o any lockers could be around $500-$600. Unless you want to attempt it yourself or know someone who'll help you.
Where can I buy
>gears?
(www.summitracing.com) has gear sets at $195.
I don't even know
>what type of axles are
>in there. Ford 9 in
>the back? Dana 40 up
>front?
Probably it has a Dana 44 IFS up front and a Ford 8.8. in the rear. Check your door code for a number and someone on here will tell you what it is.
Can U get the
>gear set from the dealer?
Yes, probably but that would be mighty expensive.
i still think you should ditch the 289/302 motor you have and go with 351 or460!!!.
the 351 will cost the least in additional parts to get it to fit , but the 460 will pull like you can't imagine.
if you start changing rears, the rpm range changes and you get more power to the ground, but you have to spend bucks to do it.
i am glad you checked the timing as i suggested in my first reply,not having spark advance can really affect power.
just curious, why is getting rid of 289 not an option?
