68 Ford F600
Did you notice 352 cast into the block, drivers side front?
All the FE 352/360/390 blocks are cast as 352's, only when they are finished can they be something else...so, you could have a 360 or 390 engine.
Measure the stroke: 352/360 = 3.50" / 390 = 3.78"
Look at the flywheel, they all are stamped with flywheel ID numbers on them.
Post what you find. **
352/360's use an 11" clutch on a 12 3/8" diameter bolt circle.
390's use an 11 1/2" clutch on a 12 7/8" diameter bolt circle.
330 M/D's use a 12" clutch on a 12 7/8" bolt circle or a 13" clutch on a 14 1/8" diameter bolt circle.
** I will be away from the 10th to the 20th of May, so FTE member Air Harley is the only other person (that I know of here) that has the same parts catalog, is qualfied to use it, and can ID the flywheel.
As for the numbers on the differential: on the top directly just a little behind where the driveline enters are stamped 50341 and 631186. I didn't find any numbers on the axel housing. On the 2 speed top is canada: 2807 510 002, Eaton 40635. I don't know if that gets anywhere to determine what it actually is.
The fact of the matter is, Ford lists two Eaton 2 speed axles for 1968/72 F600's, 15M and 17M (models 13802 and 15201), a third & fourth for C Series Tilt Cabs and the N Series only, model numbers: 16802-3 / 16220-1. Different parts list for these two: #101.
Then take this into consideration: Domestic Special Order.
16220 was also installed in f-600 and f-700
I did take DSO into consideration as all our trucks were ordered not bought from dealer stock
if I had my library here I have all the books on '68 medium duty trucks,even the dealer propagana sheets and buildsheets
we bought 4 new '68 f-600s
Later flange diameter is 2 1/8."
C5A is a car dizzy ID number, but there's more to it like: C5AF-12127-A / B / AD / AE.
1965 cars came with 352 or 390 engines.
Look on the exhaust manifold for ID numbers, cars with 352/390's used different exhaust manifold than trucks with 352/360/390's did.
The FT (330/361/391) engines used Rams Horn manifolds.
None of this proves anything, parts can be swapped around, so who knows what the engine is.
I couldn't find a thing on those axle numbers you posted.
Look here: Stamped into the right back side of the axle tube just to the right of the inspection cover, there are two numbers.
Top number refers to the housing number / Bottom number refers to the series ID number.
I won't be here to decode them, so mebbe Ray can help you.
