Fun repairs await me....
Old May 9, 2008 | 06:14 PM
Pocket's Avatar
Pocket
Yes I have the in-tank and pre-pump mods. Did that a few years ago. I do still have the stock fuel pump, and it's the old original with 108K miles on it now.
Old May 9, 2008 | 06:17 PM
Pocket's Avatar
Pocket
Originally Posted by beer boy
if its not the pump, or the filter. try checking the pressure spring and the seat. but it sounds like a pump to me lossing power for what ever reason. tap into the 12v supply for the pump and monitor it as the problem happens. cheap. easy. have you checked the pressure just cycling the key on and off. the pump truns for a few secs. see what the pressure does then.
Well, the stock regulator is completly bypassed. I have a regulated return kit on my engine now.
And yeah I was going to try to monitor the voltage at the pump to see what was happening.
As for the cycling the key, I did that earlier today too. Everything was normal when I tried it. This problem just pops up whenever it feels like it.
Old May 9, 2008 | 06:22 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Check the fuel cutoff in the passenger side kick panel? Maybe it's moved and it trying to cut you off?
Old May 9, 2008 | 06:23 PM
beer boy's Avatar
beer boy
still sound like the pump. but if you have the org pump on hand i wouldnt bat an eye at installing it just to try it. good luck.
cheers.
Old May 9, 2008 | 06:40 PM
F350-6's Avatar
F350-6
Intermittent issues are a PIA to deal with. I feel for you. Could you temporarily hard wire a volt meter to your fuel pump to check for current issues next time it acts up?
Pocket's Avatar
Pocket
Didn't think about that one..... Something to look at.
Old May 9, 2008 | 06:41 PM
Pocket's Avatar
Pocket
That's what I was thinking of doing. I've got some wire, taps, and alligator clips Pretty sure I can rig something up.
Old May 9, 2008 | 07:04 PM
cookie88's Avatar
cookie88
FTE Emeritus
I was just digging through the service manual.....I can't even find a reference for P1203. No diagnostic subroutines at all.
Old May 9, 2008 | 07:08 PM
F350-6's Avatar
F350-6
Me too. Considering the in tank mods, the only other useful bit of information I could come up with was the check valves located in the heads at the fuel line. A bad check valve can cause a loss of pressure in one of the fuel rails.
Old May 9, 2008 | 07:21 PM
Pocket's Avatar
Pocket
Hmmmm, it's what AE pulled up.
Old May 9, 2008 | 07:25 PM
cookie88's Avatar
cookie88
FTE Emeritus
An electrical issue with a loss of fuel pressure might come from the injectors too.....maybe a buzz test?
There are all kinds of crazy codes in that manual that don't show up on the main page.....I'll keep digging.
Pocket's Avatar
Pocket
Well, Kainers left me a message over on another forum. He had a fuel pump die on him, and the same code popped up when it happened. So I guess the code does exist, and it's in reference to the fuel pump.
Old May 9, 2008 | 07:26 PM
  #28
Pocket's Avatar
Pocket
Oh, and I did a buzz test this morning too.
Old May 9, 2008 | 07:34 PM
  #29
megawatt00's Avatar
megawatt00
Curtis do you think that BigKen may be able to help you with the code? He works at Ford of Greenfield in Greenfield MA
Old May 9, 2008 | 07:36 PM
  #30
HKusp's Avatar
HKusp
I have to think that there is a loose or chaffed wire somewhere Curtis. The fuel pump voltage must be jumping because of it. I also think as a second option, there could be some loose debris in the line somewhere that may be obstructing flow.
