Well it has finally happened. My truck is at the dealership for coolant puking issues. It has puked once before while driving onto a side walk. Yesterday I pulled my Toy Hauler out to the desert to ride dirt bikes and I lost 2 gallons of coolant through the degas bottle cap. I lost one more gallon on the way home and had to pour plain tap water in. The temperature never got hot but the there was coolant all over my air box, front drive shaft, radius arms and steps. I hope they go ahead and diagnose the head gaskets so I can order up some ARP head studs. I am still running the truck stock without tunes because I just installed my gauges and wanted to get a baseline first so no problems there. I found studs for $409. Anyone know a cheaper place that will overnite them?
yes, the waiver states that any failure that could have possibly been caused by the studs will void the warranty. I will make sure they check the heads thoroughly.
