Fact or Fiction
Old Oct 29, 2000 | 10:59 AM
jopey's Avatar
jopey
Fact or Fiction
I heard from some mechanic that 302's have a problem with the rocker arms hitting the retaining clips on stock heads thus driving the valve into the combustion chamber.
I think he was talkin out his ****!
Old Oct 29, 2000 | 10:35 PM
DBF's Avatar
DBF
Fact or Fiction
Don,
The rockers can hit the upper collar of the spring. The rocker arm has a rib on either side of the arm over the valve, this is one of two ways Ford aligned the arm over the valve. As the rocker and valve stem wear, it's not uncommon to have the ribs contacting the collar. This can be modified with pushrod guide plates that controll the rocker arm by controlling the pushrod. It requires hardened pushrods and plates and usually the mounting pad has to be milled down .300 to make room for the plate. He's not talking out his ****.
Jim
Old Oct 29, 2000 | 11:34 PM
jopey's Avatar
jopey
Fact or Fiction
DBF, thanks. so what does that mean in most 5.0 terms. they are junk or it takes a long time for something like this to happen!
Old Nov 16, 2000 | 10:02 AM
BB's Avatar
BB
Fact or Fiction
Well, better late than never. Jopey, this is not a problem with the 5.0L engines because they use the pedestal style rockers that aren’t guided by the valve stems.
Barry
Old Nov 28, 2000 | 05:49 AM
DBF's Avatar
DBF
Fact or Fiction
As I understand your post, if your mechanic is warning you about the rocker arms, you have a 302 before they called them 50.
The rocker begins to open the valve by pushing on the retainer which allowed the valve stem keepers to make a get-away, dropping the valve into the cylinder. It takes a considerible # of miles or neglect but if you're rebuilding an old 302, either replace the rockers with new rib, or update them with the hard plates and pushrods and the non-rib type rockers.
Jim
Old Nov 28, 2000 | 08:17 AM
jopey's Avatar
jopey
Fact or Fiction
the 302 I got right now has about 20k on her. and it was a remanufactured one.
thanks for the input.
If it is still running. you didn't try hard enuf!
Old Nov 29, 2000 | 08:20 PM
jopey's Avatar
jopey
Fact or Fiction
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
