alright 433 it is then. So what is the first thing I need to do. Im trying to understand all this stuff but is definetly way different from the gassers. I need someone to tell me the steps in getting the safest max horsepower without doing alot of internal expensive work. Do I do injectors, turbo, or hpop first and how do I know what to get???
Nope, you go over 400 with your PMR engine and you stand a good chance of being in the
"I need a new engine block" thread.
Rich, do you think some175/146 Single Shot injectors first then, van turbo or BB unit and not even go big oil route? With PMR's is big oil even a good idea?
with my setup I am at 350 hp - 175/146 single shot inj, van turbo, stock HPOP. With these injectors my HPOP can maintain 3200 psi and don't throw the SES light anymore. But I'm still wanting to put in dieselsites Pulse HPOP.
Mike (Tenn01psd350) is at 400 hp with swamps 200cc hybrids, BB turbo & stock HPOP
I think Jeremy (JTHArvey) was at the 340 hp range with stock injectors, BTS dual HPOP, Van turbo
Kevin (mech2161) suggested -- van turbo, hybrid 530 injectors, intake and exhaust will get you to 400 also
Ok I think I like Tenn01psd350 setup. I got on black cloud diesel and it said that you could run those injectors with stock HPOP and stock turbo if you wanted. I would like to upgrade the turbo eventually. One more question. What is PMR and also wonder what kinda mpg im gonna get if I switch to these 200cc hybrids???
Ben (Soaggydogg) is running a set of 160cc single shots with an H2E turbo, BTS big oil in his Excursion and he is running around the same HP level as I am.
