Downshift linkage
Old May 7, 2008 | 07:58 PM
steel1970's Avatar
steel1970
Downshift linkage
I have a 1978 F150 that the previous owner had changed the carb and intake. The 351M came with a 2 barrel, and he put an Edelbrock manifold with a Holley 4 barrel carb on it. I was looking the other day, and noticed a linkage that was not connected to the carb, but was dangling there in plain sight. After further review, realized it was the downshift linkage. How does it connect? There is no mechanism on the carb for it to attach to. I looked at my brothers truck, same motor but with the factory setup 2 barrel. It has a separate mechanism which sits behind the throttle on the carb, and when you gun it it pushes the downshift linkage down, and, well, you know the rest. Where can I find what I need for this non-stock carb?
Old May 7, 2008 | 08:07 PM
fmc400's Avatar
fmc400
MSEE
There are a handful of kits that will adapt. A Holley should have the mechanism needed. If all else fails you can get a kit from Lokar to hook it up. Look around Summit's website; they will have what you need.
Old May 7, 2008 | 08:16 PM
steel1970's Avatar
steel1970
Thanks for the help. Any good info is appreciated!!
55fordf100Gramps
Apr 11, 2013 06:20 PM
ItStillRuns
Mar 30, 2013 10:50 AM
johaner78
Dec 22, 2011 04:44 PM
runcrashboy
May 9, 2004 10:55 AM
