302 engine rebuilding options
Old Dec 16, 2000 | 09:21 PM
jopey's Avatar
jopey
would parts they make for mustangs and all hold up to the stresses of 4x4's?
if so. I was thinking about a 347 stroker kit slapped in a 302. kinda a sleeper in my eyes.
any good sites on the net to get parts from?
I figure that is what I will save up to do when my current engine goes south!
If it is still running. you didn't try hard enuf!
Old Dec 18, 2000 | 04:41 PM
PaulL1's Avatar
PaulL1
Mustang parts would hold up fine in your truck, but would your truck hold up to a 347? I would go for a fresh 302,30 over,nice low end roller cam(Lunati),good set of aftermarket heads(aluminium for about$1,000), and have your upper and lower intakes extrude honed. Top this off with a larger throttle body and shorty headers with cat back ehxaust,and your talking sweeet!
Old Dec 18, 2000 | 06:52 PM
Pastmaster's Avatar
Pastmaster
The 347 stroker can make some mean hp numbers, but I don't think it's all that reliable. It deffinantly isn't cheap. You have to have the 302 block bored .030 over. As well as a 3.4" crank.
Pastmaster's 1993 XLT 5.0 E40d 3.55LS Normal Cab/Long bed Loaded from the factory with aid of...MSd 6a ign/s.p. wires, blaster coil, Hypertech Chip, K&N filtercharger, Cat-back dual exhuast w/o mufflers, 3.5", echo tips, Accel distributor cap, Dark Mocha over light mocha. 5% Dark tint, Alpine Cd player/remote, Pioneer speakers.
toydestroyer1(No Email Addresses In Posts!)
Old Jan 1, 2001 | 02:45 AM
ecodbertels's Avatar
ecodbertels
A 347 Stroker is definetly worth it. I built one for one of my customers mustang. If you are going to stroke it you should also update the heads. I installed 1969 351 4V windsor heads on my customers motor. I performed a 3/4 angle grind on them and ported them. I then installed a cam with a .544 lift. Since this was a monstrous cam I had to enlarge the notch on top of the pistons. But if you are going to put in a stroker this should be no problem. You can also pay someone to do it. If you live near Dayton Ohio I will gladly build your motor. Just stop by my shop. I can use the work. All I get in there now is chevy and foreign crap. I enjoy building ford motors. They are very rare(The high HP kind).
Old Jan 1, 2001 | 09:02 PM
killer5pnto's Avatar
killer5pnto
I think the mustang partswould be able to take it.
Old Jan 3, 2001 | 07:11 PM
KevinT's Avatar
KevinT
If you're rebuilding a EFI you also might want to take a look at explorer 5.0 parts, the `98 explorers I'm postive have GT-40 aluminum heads, and the intakes on them are nice round ovals, even better than the mustang H.O's have, it would be the best combo to go with mustang H.O. internals and a mass-air conversion with explorer heads, intake, and throttle body
1995 F-150 XL Reg Cab/Bed
http://members.sounddomain.com/blind
5-star rated F-150 (big stereo)
Old Jan 4, 2001 | 05:52 PM
lvstang's Avatar
lvstang
The Explorer GT-40 heads ARE NOT GT-40 aluminum heads. ALL the current crate Explorer motors use an iron GT-40 "P" head. The "P" head is a decent head with a different plug location that makes header selection a little tricky. There is a specific "P" header for Mustangs but I'm not sure about Broncos. I have been able to use FMS shorty headers on a Mustang with "P" heads but had to fabricate a spark plug wrench and get plug wire protectors. If you find a junk yard Explorer the first year that they used the 5.0 it may have the standard GT-40 iron head that uses the standard header. Everything after is an iron GT-40 "P" head.
Old Jan 4, 2001 | 05:58 PM
lvstang's Avatar
lvstang
The only negative I've ever seen on a 347 stroker with 5.4" rods is that the oil ring goes across the piston pin. This may or may not cause oil control issues depending on many combos. I believe it is Coast High Performance in Cali. that offers a a slightly shorter rod that lets the bottom oil ring miss going across the pin. A very popular stroker right now is the 331 which offers a better rod ratio with no oil control poblems.
Most stroker kits offer as good if not better parts than OEM and durability should not be an issue.
Old Jan 4, 2001 | 10:37 PM
DBF's Avatar
DBF
Undertheoaks
Mar 30, 2014 09:48 PM
jg09
Oct 3, 2013 02:34 PM
74X4VAN
Engine Swaps
Jan 19, 2008 09:49 AM
Aekisu
Feb 23, 2004 12:58 AM
smokey-2
Dec 14, 2003 10:19 AM
