Front cowl vent
Old May 7, 2008 | 01:01 PM
tip49's Avatar
tip49
Front cowl vent
The body guy removed the front cowl vent from my 50; to paint. What is best way to re-install it without damaging the paint ? It would seem to need to go in at an angle, but the actuator rod seems to prevent further movement.
Tom
Old May 7, 2008 | 01:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It's tight, very tight, but if you take the nut off the actuator so it can flop around, the frame will go in at an angle. I recall having to get part of the frame in one of the cutouts near the screw holes, does that make sense? Gains a precious 1/8" or so.
Old May 7, 2008 | 02:02 PM
tip49's Avatar
tip49
Thanks Ross; I'll mask it off and try this weekend when I get home.
Later
Tom
Old May 13, 2008 | 08:09 AM
gifuneod's Avatar
gifuneod
Cowl Vent
Did you ever get the vent assy in? I saw your post and decided to try and get mine in before going to the painter the thing just doesn't fit. When I took it out the handle was broken off and it was still a job to get out.
Old May 13, 2008 | 08:14 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I don't remember all the details, but I'm pretty sure you have to take the bolt/nut out of the linkage connected to the handle. Then you cork-screw the handle thru the opening. It took me a couple tries!
Old May 13, 2008 | 11:11 AM
51ford fan's Avatar
51ford fan
I taped all around mine when I installed it and the tape worked out well preventing nicks.
Old May 13, 2008 | 12:04 PM
gifuneod's Avatar
gifuneod
Cowl Vent
Thanks All, I'm glad tip49 mentioned it before the truck was painted so I can play with it without screwing up the paint. I think the truck will get painted with it installed.
Old May 13, 2008 | 09:26 PM
Julies Cool F1's Avatar
Julies Cool F1
Be sure to take the cover off then install the mechanism. Cover goes on after frame work is in.
Drop the handle side in first at an angle tilted down, then tilt it back, then drop in the passenger side.
If you have an aftermarket wiper motor, you may have to take that out to get the vent back in.
Old May 14, 2008 | 10:22 AM
tip49's Avatar
tip49
didn't try yet
Last weekend did not get time to try to install the vent; I need to buy the rubber seal before I try it. I did manage to start the wire harness install, through the firewall. I now have the wiring harness cut apart, hope I get to it soon before I forget how it all goes together.
Later
Tom
Old May 14, 2008 | 12:16 PM
48fordcoe's Avatar
48fordcoe
the cowl vent is the biggest pain ,but it the beat thing to have on the truck .I use my more then the A/C
Old May 14, 2008 | 01:48 PM
49willard's Avatar
49willard
Ah, another truck with AC that saved the cowl vent. I agree and am going the same route!
tip49
May 26, 2014 10:27 AM
John Morton
Oct 27, 2013 12:38 AM
Randy Jack
17
Jul 24, 2005 11:50 AM
Matts68f100
Apr 21, 2003 08:04 PM
classyfish
Paint & Bodywork
Feb 25, 2003 11:44 PM
