radiators e350v f350
Old May 7, 2008 | 10:11 AM
mrblonde108's Avatar
mrblonde108
My fan went through my radiator. I know someone who has a e350 radiator will it fit in a f350??
Old May 7, 2008 | 09:45 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Depends, there are two styles used in the F series.
The most common one is tall and narrow, which probably would not fit an E series.
The other is wider and shorter, which probably would fit an E series.
Measure the core size from the top of the bottom tank to the bottom of the top tank.
Then measure the width of the core between the side brackets.
Old May 8, 2008 | 06:51 AM
Dodge/Cummins's Avatar
Dodge/Cummins
Is the E-350 a diesel?
Dave,
Does it matter?
Old May 8, 2008 | 07:34 AM
mrblonde108
yes its diesel/ Also what about f350 v f450 superduty chassis/ Is it the same?? I know suspension is different 10 lugs and springs but what about frame rails?? i'm talking 1990 here
Old May 8, 2008 | 09:46 PM
Dave Sponaugle
The front of the frame should be the same, the back of the frame may or may not be the same.
F 350 was offered as a cab and chassis as well as a pickup.
The F 450 was a cab and chassis only.
Cab and chassis trucks have a 34" rear frame rail width, and the rails are flat on top.
Pickups have a 37.5" frame rail width and a hump over the rear axle.
But the front of the frames are identical on all of them.
Most diesel radiators are four core, very few gassers are.
And the inlet and outlet locations may be different.
kyle j
36
May 21, 2015 06:01 PM
mexicanfooddude
Nov 12, 2013 09:53 PM
adamkat22
Dec 5, 2012 09:14 AM
jf350
Apr 19, 2007 09:40 PM
