Oil in Radiator?
Old Apr 19, 2007 | 07:47 PM
jf350's Avatar
jf350
Oil in Radiator?
Just checked my radiator fluid and it looked black. I assume this is engine oil. If so, how is it getting in the radiator? Any suggestions? How big a problem is it?
1988 F350 7.3 diesel 5spd Banks turbo.
Old Apr 19, 2007 | 08:11 PM
eco's Avatar
eco
I would consider this a big problem. Is coolant getting into the oil? Coolant breaks down oil quickly.
The only ways that I know of for oil and coolant to mix are head gasket leaks and timing cover gasket leaks. Other than that there are things like cracked head/block etc. but not that common.
And coolant/oil mixtures as I have seen them look more like chocolate milk than black, but thats all subjective.
Old Apr 19, 2007 | 08:53 PM
gustang818's Avatar
gustang818
Does the Banks turbo have an oil cooler that uses the coolant system? I've seen engine oil get into the radiator with an internal oil cooler failure.
Old Apr 19, 2007 | 09:40 PM
jf350's Avatar
jf350
No, the Banks doesn't have a separate cooler. The Banks was installed several years ago. I did change the water pump myself about a year ago. However, I checked things pretty carefully for several months thereafter. There's lots of oil all over the front of the engine so gaskets sounds possible.
kupiec20
Jan 19, 2015 11:05 AM
abe
Dec 13, 2014 05:42 PM
TonyG
Oil & Lubrication
Apr 21, 2013 11:06 AM
struttin
Aug 27, 2009 08:17 PM
