Help with error light
Old May 7, 2008 | 09:01 AM
Ronni's Avatar
Ronni
I have a 2006 Ford Expedition XLT. When I turn the heat on, about twenty minutes later, I get the error light. Now, the odometer gauge, fuel or oil gauge needles will not move. What could this be and how much will this cost me?
Old May 7, 2008 | 11:20 AM
deltasoft's Avatar
deltasoft
if still under warranty take it to dealership....if not i would check the odometer fully for and wiring going to such, as when you turn heater on....perhaps cables are close to a vacum or close to heater in a way melting cables or causing a temperature change on the wire...........
cant say i have an 06 but i would check that out first........and yes odometers are quite expensive......unless you hit the junk yard....
Old May 7, 2008 | 01:40 PM
sbclemens's Avatar
sbclemens
If you're getting an error code, which one is it?
6Fords
2004 - 2008 F150
Oct 29, 2013 08:27 PM
2000expedition4x4
May 29, 2012 05:23 PM
Ian123
Jan 5, 2010 05:22 PM
cnajp
Electrical Systems/Wiring
Apr 27, 2005 10:21 PM
james2000
Aug 10, 2004 02:54 PM
