Error Code
Old Aug 9, 2004 | 09:19 PM
james2000's Avatar
james2000
Error Code
I have a 1994 f-150 and i am getting a flashing dashboard light that come out to the error of "32" . I would like to know what this error means and how to fix it.
Old Aug 9, 2004 | 09:25 PM
MustangGT221's Avatar
MustangGT221
It means either:
EVP circuit below minimum voltage of 0.24 volts
Or
EVP circuit has intermittently failed below minimum voltage of 0.24 volts
Depends on which test you were looking at, the KOEO and KOER were for the 1st option...and the 2nd was for the continuous memory (CM).
Old Aug 9, 2004 | 09:27 PM
EPNCSU2006's Avatar
EPNCSU2006
I'm thinking this might be an airbag code. The "Check Engine" light would flash the codes, but you have to initiate that test manually. The airbag light will flash every time you turn the truck on. I have no idea what the code 32 means for airbag...
Old Aug 9, 2004 | 09:47 PM
xltlariat87's Avatar
xltlariat87
evp voltage below closed limit
Old Aug 10, 2004 | 02:54 PM
EPNCSU2006's Avatar
EPNCSU2006
I don't think he is running a diagnostic test...
cbrown_63
Nov 21, 2010 09:24 AM
raptor2005
Feb 15, 2010 03:03 PM
