EBPS cleaning question
Old May 6, 2008 | 09:05 PM
superduty4x4's Avatar
superduty4x4
I tackled this job tonight, it's about in line with my level of competency with this truck I don't have a deep enough 1" socket to remove the EBPS itself, so I took the tube loose and gave it a once-over- almost no soot whatsoever and no holes or cracks.
My question is this- since the tube was nice and clean, what are the chances the sensor is plugged up? I shot some carb cleaner up into it and it came out pretty clean. Should I look for a 1" deep socket or just not worry about it?
Old May 6, 2008 | 09:17 PM
bigsteve1969's Avatar
bigsteve1969
i just did this sat. and my TUBE is what was clogged so bad it took 30 min of just soakin it to break half of the soot loose thin took weed eater wire and had to work it through! i would pull it all off and check but if you dont have a deep socket well you dont have a deep socket. I actually had to use one of my impact sockets for that big of deep well.
Old May 6, 2008 | 09:21 PM
bigsteve1969
cancel that last post.... just focused on what you wrote!! if you took off your tube and it wasn't packed i wouldn worry bout much but it could still be the sensor what kinda mpg?
Old May 6, 2008 | 09:29 PM
big poppa's Avatar
big poppa
I still didn't do this yet, maybe tomorrow.
Old May 6, 2008 | 11:28 PM
superduty4x4
Originally Posted by bigsteve1969
what kinda mpg?
15.5 mpg with a mix of freeway (2400rpm) and highway driving (1900 rpm) with 450 pounds in the back.
Old May 7, 2008 | 03:24 AM
Chance_Thomas's Avatar
Chance_Thomas
Are you throwing a code?
Old May 7, 2008 | 04:22 AM
Kwikkordead's Avatar
Kwikkordead
I had to replace both the tube and the sensor on mine.
The tube had rusted through and the sensor was filled with this rock hard black sooty looking stuff so full I didn't think it would clean out all the way.
Old May 7, 2008 | 08:58 AM
superduty4x4
No idea. I have an SES light but that's due to glow plugs (CA emissions truck). My only way to check codes would be to pay the dealer $33 to do it for me.
Old May 7, 2008 | 05:38 PM
bigsteve1969
anybody close to you with a code reader? i've heard that some of those used at places like auto zone etc. will not read all the codes for our trucks. if i had one i would send it to ya but i aint got around to buying one yet! and you KNOW for a fact the ses light is due to the glowplugs... and you may wanna just get the cost of new tube and sensor that way you know that its all new! just a thought
Old May 7, 2008 | 06:51 PM
HKusp's Avatar
HKusp
Still has the issue of the 1" socket to deal with. Buy the socket and check it. Don't buy a sensor AND a socket to change something that you may not need to replace.
Old May 7, 2008 | 06:59 PM
kawika's Avatar
kawika
Have you tried blowing air thru the tube to see if it is clogged? I can't imagine a clean ebps tube and sensor. What ever you do, don't stick anything up the Sensor hole. You may damage the "window" up in the sensor. Mine was so plugged, thet the holder that the sensor was screwed into was also plugged.
Dave.
Old May 7, 2008 | 07:47 PM
8tsixt's Avatar
8tsixt
I need to check mine soon. I keep forgeting.
Old May 7, 2008 | 09:08 PM
superduty4x4
Dave.
There was nothing of significance in the tube, I could easily blow air through it. I shot carb cleaner through it just to be safe, then stuck the nozzle on the carb cleaner (skinny little tube thing) into the sensor and shot cleaner up there as well.
I don't know anyone with a code reader, unless the guy who reads the codes at the stealership will take it home with him and not charge me (hey, he loaned me a part for my old truck to test something out...) I know for a fact the SES light is due to glow plugs because I took it in and had it read when it first threw the light.
Old May 7, 2008 | 09:38 PM
JOE-M's Avatar
JOE-M
If you'll watch on Ebay you can sometimes pick up a Superchips tuner that is vin locked very cheap. There was one on there the other day that was $25. The code reader part will still work fine even though it is locked.
Joe
Old May 7, 2008 | 10:02 PM
superduty4x4
Good idea JOE-M, I'll have to try that.
