tran fluid
Old May 6, 2008 | 01:51 PM
SBastow's Avatar
SBastow
tran fluid
99 Exp EB 100K Tranny fluid prob never been changed. Should I get fluid changed or leave it be. I've heard changing fluid may cause harm if it has never been changed after this many miles? Any truth to that or just BS?
Old May 6, 2008 | 10:57 PM
sbclemens's Avatar
sbclemens
Change it. Change the filter and drain the torque converter while your at it.
Old May 7, 2008 | 08:21 AM
broncoholic's Avatar
broncoholic
New fluid has killed trannys before, BUT that only happens when the tranny is worn out and will be dieing on its own soon anyway. What usually happens is a worn out seal will blow because the new fluid can hold higher line pressures. Bottom line, change it. If nothing happens with in a couple hundred miles, then your tranny should be in good shape.
mps_987
Jul 19, 2021 07:16 PM
B 3000
Escape & Escape Hybrid
Feb 18, 2010 06:41 PM
cavitation
Jan 26, 2010 10:46 AM
gdfrick122
May 30, 2008 11:33 PM
LARIAT 85
Oct 3, 2007 01:27 PM
