1973 351w timing?
Old Mar 11, 2001 | 09:34 PM
mattd32208's Avatar
mattd32208
1973 351w timing?
I have a 1973 351 Windsor that I recently installed into a 1977 Ford F-100 S.W.B.. I have had it rebuilt and bored .60 over and installed an Edelbrock Performer 351-W intake and placed an Edelbrock 600cfm carb on top. I also recently installed a K&N air filter assembly on it. One of my questions is what is the best timing that I should set the engine at to achieve good performance(and a little fuel economy if possible)? It tends to want to hesitate sometimes and wants to backfire slightly once in a while as a start it. It also takes me a couple of tries to get the engine running and not shut off on me when I first start it. It's kind of strange really because when it is really cold like around 40 degrees it will fire up and stay running on the first try. Every thing electrical on the engine is new.
Old Mar 11, 2001 | 10:50 PM
Franklin2's Avatar
Franklin2
1973 351w timing?
Warm it up and take it and a 1/2" wrench out on the road. Find
a slight hill and really put a load on the motor (leave it in
high gear). Turn the distributor to advance the timing until
it pings. Listen carefully if you have loud exhaust. Turn it
back until the pinging goes away. Take it back home and shut the
motor off. Let it sit for a minute and try to restart the motor.
It should spin fine and start. If the starter struggles a little
turn the timing back a little more till the starter turns the motor easily. You can do this procedure with or without the
vacuum advance hose hooked up. I personally had a better running
engine with the timing set without it hooked up and then buying an adjustable vacuum advance and set it with the road procedure
described above.
Old Mar 12, 2001 | 07:29 PM
arusj's Avatar
arusj
1973 351w timing?
hail destroyer
Apr 22, 2016 10:21 AM
jbehuniak
Ford Truck Parts for Sale
Feb 20, 2016 01:26 PM
Fishbowlfire
Dec 3, 2014 09:12 PM
derk001
25
Aug 9, 2012 05:49 AM
JB78f150
Dec 31, 2011 09:51 PM
