throttle body 302
Old Feb 4, 2001 | 05:26 PM
powerstroker1234's Avatar
powerstroker1234
throttle body 302
Today I replaced the intake gaskets due to a coolant leak. After putting it back together and retiming the distributor(had to remove to get intake off) I can't get it to idle. It just dies unless holding it at a high rpm. Is there a sensor bad? I can't find any vacuum leaks. Any help is appreciated. Thanks, Les
Old Mar 12, 2001 | 07:29 PM
arusj's Avatar
arusj
throttle body 302
I wonder if when you timed it, if you removed the timing plug.
Run your hand down the Ignition Module wiring harness until you feel a small plug on a single wire, I don't know what color. Remove this plug. Remove the vacuum advance hose and plug it so that no vacuum leaks. Time it to 10 degrees, replace the hose and plug, and you should be set, hopefully.
Old Mar 13, 2001 | 05:43 AM
mjb1962's Avatar
mjb1962
throttle body 302
lsmcnabb
Oct 13, 2014 04:54 PM
Catherine M Fisher
39
Apr 14, 2013 09:47 AM
Joe_Temp
Dec 12, 2011 03:05 PM
brthevio
Mar 28, 2009 03:53 AM
GFDHoytJr
Apr 22, 2004 03:10 PM
