General Automotive Discussion
Ford 255ci V8
Old Feb 27, 2005 | 02:12 AM
Dariand1's Avatar
Dariand1
Ford 255ci V8
Does anybody remember the Ford 255ci V8 back in the early 1980's, I believe that it was used on the Fox bodied cars and the full size Ford's, how good was those engines?
Old Feb 27, 2005 | 07:50 AM
76supercab2's Avatar
76supercab2
I remember them. IIRC they had nylon timing gears. Generally underpowered for thier application. No performance part available for them. And the most telling thing, Ford dropped them in favor of the 302 after a very short run.
Probably ok if low miles/ well maintained for a grocery getter. Dump it if you want performance.
Old Feb 27, 2005 | 10:09 AM
mikebon08's Avatar
mikebon08
The owner of the store where I worked in high school had an '81 or '82 Thunderbird with a 255. Seemed to run okay but wasn't the quickest thing on wheels.
Old Feb 27, 2005 | 10:15 AM
stevef100s's Avatar
stevef100s
You can't even get a 4 barrel intake for one of those slugs.
Old Feb 27, 2005 | 10:51 AM
mikebon08's Avatar
mikebon08
I don't think a 4-barrel would help it anyway. Not enough engine to start with. It was tuned for economy and emissions. The only reason it moved at all was because the car was much smaller and lighter.
Old Feb 27, 2005 | 11:08 AM
TigerDan's Avatar
TigerDan
I was talking with the guy at the Post Office the other day, he said he had a Falcon that he'd put a 255 into (I didn't ask why he'd bothered.) He said he'd put 302 heads on it, which really woke it up. Okaaaayy....what occurs to me is that 302s are much more plentiful than 255s anyway. He must have just happened on to one for a good price. I've never messed with one personally. Years ago I knew a guy who had put a 221 into a Jeep. First one of those I ever saw, I think they are even more rare than the 255. -TD
Old Feb 27, 2005 | 04:20 PM
Bart99GT's Avatar
Bart99GT
A 255 is in the same family as the 221/260/289/302/351. The only difference between it and the 302 is that the 302 has a 4" bore, and the 255 has a 3.68" bore. So the heads and intake will swap between the two, but why you'd bother with such a swap is beyond me. The only 255 I can recall seeing was in a 1980 Mustang that someone had restored and preserved the original motor just so it would be concours correct. I imagine anyone else with half a brain probably pulled those 130 hp turds out along time ago.
Old Feb 27, 2005 | 04:44 PM
Dariand1's Avatar
Dariand1
Didn't they get the idea of a 255ci V8 from Chevrolet's 267 ci V8 which was used from the late 70's to the early 80's?
Old Feb 27, 2005 | 08:35 PM
Bart99GT's Avatar
Bart99GT
Possibly. I think it was just an attempt to use what was on hand to create a more fuel efficient V8. By using the basic SBF design it allowed them to keep costs down because just about everything but the pistons and rings could be borrowed from the 302 and 351 which Ford continued to use in the larger cars (Grand Marquis, Lincolns, etc) and in the trucks.
Old Feb 27, 2005 | 10:44 PM
85e150's Avatar
85e150
Don't know who got the idea from whom, but it's the same idea: Take an existing engine and reduce the CID in hopes of better MPG.
Old Mar 2, 2005 | 04:59 PM
tbirdscott's Avatar
tbirdscott
The 255 isnt worth anything unless you are doing a full resto of a car that was unfortunatre enough to be built with one.
255 Thread here
Old Mar 2, 2005 | 10:25 PM
RangerRuss's Avatar
RangerRuss
We had some Fairmonts with that engine that had been converted to Natural Gas.
I personally think that a Studebaker V8 had better performance and they are frequently referred to as a boat anchor...
Russ
kellybeefarm
32
Feb 5, 2025 11:44 AM
64fordf100292
Dec 16, 2009 05:32 AM
55F350Dually
Flathead V8 & Flathead 6
May 20, 2005 05:45 PM
55F350Dually
Apr 2, 2005 02:56 PM
rwall0113
Apr 15, 2004 08:44 AM
