[quote=deltasoft;6219971]i advised of such on previous post lol
here's post :
Quote:
<TABLE cellSpacing=0 cellPadding=6 width="100%" border=0><TBODY><TR><TD class=alt2 style="BORDER-RIGHT: 1px inset; BORDER-TOP: 1px inset; BORDER-LEFT: 1px inset; BORDER-BOTTOM: 1px inset">i'd like to make sure my connections on starter are good (well connected) does anyone have a diagram on how to connect a starter on a 97 4x4 5.4L expy? </TD></TR></TBODY></TABLE>
Sorry, I musta missed that one.
I've got a '97 5.4L wiring diagram but I'm not smart enough to figure out how to save it and send it to you.
Hey Sean, I thought they were just what he was looking for.
Thanks. I thought so too. I found it to be pretty helpful. I hope he gets his truck fixed soon. Seems like he has been working on it for quite some time.
Sorry took long for a reply back, yes pictures helped me out a bunch thanks again!
things i tried:
i tried rotating engine to see if it is seized and rotated sigh........not seized.....
i jumpered the starter solenoid (ignition module) with key open and still no luck....makes this sound as if lets see .....u know when u hit ur hammer against the starter ?? that dry noise....(which was same noise obtaining before jumping the solenoid)
could the starter be bad after all?....................although it spinned at autozone and test came successfull???????????
thanks a bunch guys...i'll wait for ur response....
things i tried:
Try this. remove the starter. Lay it on the ground. Connect a set of jumper cables to your battery (I'm assuming the battery's good). Connect the negative battery jumper cable to the body/flange of the starter. Carefully touch the lug of the solenoid. What happens?
