good cam???
Old May 4, 2008 | 11:20 PM
factory594x4's Avatar
factory594x4
Question good cam???
I need help in choosing a cam? I have a f-250 4x4 400w/c6. I want good towing and of road power. I want the power that the 400 should be making. I want to be able to run the stock valve train, only changing the cam.
Old May 5, 2008 | 05:21 AM
hollenjoe's Avatar
hollenjoe
hmmm only the cam, with te stock low compression go with the comp cams extreme energy ex256h... and get higher gears on your rear end.....
Old May 6, 2008 | 06:35 AM
SRT77's Avatar
SRT77
Comp Cams 255DEH. It's range is 1000 to 5000 RPM and is a good low RPM towing cam. Do a search in this forum and you'll find lots of info.
Old May 6, 2008 | 03:12 PM
factory594x4
Question
I am running 4:11 w/33''s. I also have full length heddman headers I would like to use. I have an edlbrock intake w/egr. I'm in ca. After my smog test I also want to go to a 4bbl. Or sould I just advance the timming to pre-72 settings? If so what about the low comp?
Old May 6, 2008 | 06:42 PM
hollenjoe's Avatar
hollenjoe
well theres not much you can do bout factory low cr rather than buying high cr pistons or milling your heads... those 2 cams work great under your conditions
Old May 28, 2008 | 07:20 PM
relient3074's Avatar
relient3074
Totally right!!! I thought I wanted to JUST change the cam, but I wanted killer low end + CR. Ended up changing heads over to Aussie's. Best move I ever did. Aussie or 351c heads will give ya increased CR. It gave me enough to take my stepdad's 302 in 1/8's, though he slightly edges me in 1/4's. I still have the advantage 'cause I'm no SO purpose built to the strip that I sacrificed low end, so I still use my 'bump' as a hauler. Thinkin' about a cam change when time comes that I'm not haulin' with it.
Old May 28, 2008 | 07:48 PM
danlee's Avatar
danlee
Make sure that you change the timing set. You need to set the cam timing to 'straight up' instead of 4 degrees retarded as with the stock timing set.
Comp cams 255DEH or XE256 are both good. The XE256 is better for highway speeds. You will also need to change valve springs.
justforkicks
Mar 25, 2009 09:33 AM
j74250
Nov 4, 2008 02:02 PM
navarre'75
May 23, 2004 11:18 PM
maxfordfan
Offroad & 4x4
Jul 17, 2003 05:16 PM
400miller
Mar 31, 2003 08:09 PM
