Alarm system not working now
Old May 4, 2008 | 08:31 PM
waldreps's Avatar
waldreps
Hello, I have a 2000 Ranger XLT with what I presume is the factory alarm. It usually chirps twice when I press lock on the key fob. It's not the horn chirping but rather an electronic sounding bleep bleep. Well, today I disconnected my battery for a while when I cleaned my air filter. After reconnecting the battery, all that happens when I press lock on the key fob is the doors lock. No chirp at all. I noticed a spot for a fuse from a wire from the positive battery terminal to the relay for the alarm. The fuse was blown so I replaced it. Still no alarm. Any ideas?
Old May 5, 2008 | 01:00 PM
Rockledge's Avatar
Rockledge
I could be mistaken, but what you describe does not sound like the factory anti-theft system (PATS).
In and of itself, disconnecting the battery does not (or should not) affect PATS.
Also, PATS uses a specially encoded ignition key that is larger than a traditional ignition key. Do you have a key like that?
Old May 5, 2008 | 11:46 PM
waldreps's Avatar
waldreps
Rockledge,
Thanks for the response. I do have the large PATS key but this has nothing to do with that, I don't think. I must have something aftermarket. I looked over everything again and found two little plastic boxes taped together each with a fuse with the whole thing under the steering column. I pulled out both fuses to check them and when the last one went it, the alarm started going off. It must have reset it or something cause everything's working now. Not sure why that reset it and disconnecting the battery didn't but I'm happy cause it's working now. Thanks for the help.
Stacy
Relfy
Feb 20, 2013 05:10 PM
Majere26
1997 - 2003 F150
Jan 19, 2009 04:45 PM
expy98
Feb 9, 2007 12:39 PM
