Sponsored by: Auxito
burning oil
Old May 4, 2008 | 07:59 PM
fordboy_52's Avatar
fordboy_52
burning oil
2000 f250 5.4 4x4 auto, 120k and using oil. Doesnt pull very often, is this normal?
Matt
Old May 4, 2008 | 08:21 PM
99whiteford's Avatar
99whiteford
How much oil is it using????
Old May 4, 2008 | 08:28 PM
whimsey's Avatar
whimsey
Are you using or losing oil, as in the notorious head gasket fiasco with our engines. Also certain oils seem to get used more than others. I have noticed that in every vehicle I used Mobil 1 in I used more oil than with other oils. How much oil are you going through, a quart/1000 mi or more or less? In general the Ford modular engines enjoy very low oil consumption. I use Motorcraft 5W-20 in my 2002 4.6 and at worst use a very negligible amount in my 5,000 oil change intervals.
Whimsey
Old May 4, 2008 | 09:02 PM
fordboy_52's Avatar
fordboy_52
2-3 quarts every 3k oil change. using penzoil. its not leaving a puddle and runs fine. i wouldnt suspect a headgasket.
Matt
Old May 4, 2008 | 11:33 PM
Club Wagon's Avatar
Club Wagon
If you went w/FORD's normal 5000 mile oil change schedule you'd never need to change oil?
Originally Posted by fordboy_52
2-3 quarts every 3k
Oil consumption makes me think PCV & valve stem seal issues. Some EGR problems may blow oil.
Old May 6, 2008 | 01:57 AM
LxMan1's Avatar
LxMan1
I agree, try a new PCV valve first.
