Intermittent A/C
Old May 4, 2008 | 03:14 PM
xrDan's Avatar
xrDan
Intermittent A/C
I posted this in the HVAC section also...
<HR style="COLOR: #d1d1e1" SIZE=1><!-- / icon and title --><!-- message --><TABLE width="100%" border=0><TBODY><TR><TD vAlign=top>It just started to warm up enough to use the a/c with regualrity. I was on the road for about 3 hours the day before yesterday. My A/C was working fine for a while, then started blowing warmer than normal air. I turned it off for a few minutes, thinking low refrigerant might be the cause. It started working fine again, but only for a while. Then it became itermittent with cold then warm air.
I checked the refrigerant pressure today, and the guage read 35 psi.
I have a thermometer in the center vent. When the A/C works normally, it reads +/- 50 degrees. When it starts blowing warm, it will quiclky rise to +/- 90 degrees. When it blows warm, the center of the compressor pulley is not turning.
I have noticed no strange noises while driving lately that would give me a clue that something mechanical has failed (squealing, screeching, rubbing, rattling, etc).
Any ideas?
</TD></TR></TBODY></TABLE>
Old May 4, 2008 | 03:35 PM
Izzy351's Avatar
Izzy351
These compressors need shimmed sometimes after a lot of miles. Like the coil is too weak to pull the clutch in or something. Sounds like what's happening to yours. Next time it's acting up, give the clutch a little love tap and see if it pulls in.
Old May 4, 2008 | 03:36 PM
rbaker6336's Avatar
rbaker6336
the 35lb is low side pressure what is high side pressure register temps should be in low 40s
could be blend door sticking
Old May 4, 2008 | 03:56 PM
xrDan's Avatar
xrDan
While it's running?
Old May 4, 2008 | 03:57 PM
xrDan's Avatar
xrDan
What should it be?
Not sure my cheap guage is safe for too high pressure.
Izzy351's Avatar
Izzy351
Yeah. Tap the front of the clutch pack with a wrench or something and see if it pulls in. If it does, then you need to shim it. Just be careful with the fan right there!!
Old May 4, 2008 | 04:02 PM
bdrummonds's Avatar
bdrummonds
I am with Joe on this, the airgap between your clutch wheel, and pulley has probably exceeded .027. the optimal airgap between the clutchwheel and the pulley is .023 to .025. the compressor clutch rebuild kit is pretty inexpensive, so just go ahead and rebuild the thing.
Old May 4, 2008 | 04:05 PM
rbaker6336's Avatar
rbaker6336
Originally Posted by xrDan
What should it be?
you can get an idea with the low pressure guage by holding RPMs at about 1500 and see if it will hold above 25lbs at about 20 lbs the compressor will cut off
Izzy is also right about clutch shims
Old May 4, 2008 | 04:07 PM
rbaker6336's Avatar
rbaker6336
most times you can get by just removing shims
Old May 4, 2008 | 04:25 PM
xrDan's Avatar
xrDan
Roger that. I'll give it a try.
Old May 4, 2008 | 04:56 PM
SpringerPop's Avatar
SpringerPop
Some things I've posted about shimming in the past.
See Post #8 in this thread:
https://www.ford-trucks.com/forums/6...-question.html
Also, #10 in this one:
https://www.ford-trucks.com/forums/5...king-well.html
Especially #3 in this one:
https://www.ford-trucks.com/forums/5...-problems.html
Pop
Old May 4, 2008 | 05:25 PM
rbaker6336's Avatar
rbaker6336
What should it be?
you need a good set of guages to check high pressure
165-225 psi ,rule of thumb 2 times ambiant temp + 15 to 20%
Old May 4, 2008 | 06:28 PM
goldman's Avatar
goldman
I have a very similar problem on my early 99. The compressor seems to kick off when the engine is warm. Here are the weird details I have noticed. The A/C turns off when I slow down to a light. The RPM drops to about 800 the compressor switches off. The interesting part is that it will not come back on until I rev the engine to above 1500 RPM. If I am running highway speeds (1500 RPM or higher) the A/C will stay on without any problems.Pressures seem right both High and Low. The low pressure switch is working properly according to my LED experiment and now I am in the process of testing the high pressure switch. You guys seem to indicate it might be the Compressor spring or shimming. Any other ideas. Thanks
Old May 4, 2008 | 06:47 PM
rbaker6336's Avatar
rbaker6336
reasonably sure removing shims will fix you up if they haven't been removed
Old May 4, 2008 | 09:18 PM
xrDan's Avatar
xrDan
Pop
Thanks SP!
Where do I measure the air gap?
