Sponsored by: Real Truck
Torqshift Cutaway
Old May 6, 2008 | 08:10 PM
Lead Head's Avatar
Lead Head
Originally Posted by papadelogan
They need to have a 6-speed tranny that has 4 'regular' gears, 5th is the 1st OD, and 6th is the 2nd OD. My 99 has the 4R100 and if I had a double overdrive behind that, I could run 4.10s, pull heavier loads, AND get better mileage on the highway due to lower RPMs!!! They'll never do it though - the oil companies will axe-murder the engineer first.
Huh? In that case, I'm pretty sure who ever made the ZF 6 Speed for ford, or whoever designed the 6 speed manual for dodge would be long dead by now. Mercedes and Lexus have 7 - 8 speed autos now as well.
Fords 5 speed auto has "4" regular gears and one over drive. Adding another overdrive gear would require the addition of another planetary, adding a lot to expense
Old May 7, 2008 | 07:43 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by krewat
Is it "just" a TS with a different ratio set?
It is not at all related to the current TorqShift, but I'll bet they will still call it a TorqShift.
edtahaney
Jan 24, 2015 05:30 PM
labinepoirier
May 29, 2013 03:47 PM
Evan99
Apr 6, 2010 01:08 AM
brickie
Apr 27, 2009 09:02 PM
