Modular V10 (6.8l)
manifold bolts AGAIN!!!
Old May 6, 2008 | 02:17 PM
69cj's Avatar
69cj
I've never had a problem with my 428.
Old May 6, 2008 | 03:18 PM
sealer700's Avatar
sealer700
I got Lucky!!! Front bolt just turned out so I just have to put a new one in. I think the noise is coming from one of the plugs on the drivers side. THANK ALL YOU SO MUCH. I WOULD HAVE NEVER THAUGHT THAT THEY(99 V 10) SPIT PLUGS I would have found out after it blew through the roof just like the bill would have
Old May 6, 2008 | 03:59 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Was it the typical 8-bolt log of the truck FE's, or the cast-iron header type, with 14 or whatever number it was?
Old May 6, 2008 | 09:03 PM
ol'yeller's Avatar
ol'yeller
Mine are being done right now. I hope to pick up my truck tomorrow evening. My mechanic thought that the reason why the dealer price was so high is because they would pull the engine to do the repair. He said his guy dulled 6 bits and broke 2 extractors while repairing mine. Not to repeat what I said in other posts but they had to drill out 10 of the 20 studs and helicoil them. He drilled out the last one this morning. As for cost, I have no idea. He said they would only do it on a time & material basis which is certainly fair. They had the truck 2 weeks so they could work it in around other jobs. I expect the bill to run me $500-$1,000 for the manifold work alone. The new studs are installed with antisieze which should make this job a little easier next time (if there is a next time).
Old May 13, 2008 | 08:31 AM
69cj's Avatar
69cj
I have the CJ heads with cast iron headers.
jonnykford
1983 - 2012 Ranger & B-Series
Nov 28, 2010 07:35 PM
kswayze
Jul 24, 2007 04:08 PM
mossygoose
Modular V10 (6.8l)
Jun 17, 2004 12:28 PM
crabbybill
2004 - 2008 F150
25
Jun 3, 2004 12:24 AM
