Transgo tugger kit question
Old May 1, 2008 | 10:24 PM
slk133's Avatar
slk133
Hey guys got the tugger kit for my tranny (4r100)thinking about installing it till I went through the instructions. Has anyone does this kit themselves? Hard or easy to do, or is there better instructions than what comes with the kit?
Thanks
Old May 1, 2008 | 10:56 PM
Tenn01PSD350's Avatar
Tenn01PSD350
There aren't better instructions. I believe it says right on the box " for professional use only" or something like that. You are supposed to know what you are doing already. Izzy has installed the Tugger and I have installed the E40D-HD2 kit which is very similar. Just toss out the instructions, then look for a place to install all of this:
JK. What do you want to know specifically? Are you pulling the tranny?
Old May 2, 2008 | 04:35 AM
sleek122's Avatar
sleek122
Subscribing, I am going to be doing this very soon also.
Old May 2, 2008 | 07:19 AM
mueckster's Avatar
mueckster
Go the Transgo website for some installation videos. See here: Ford Lincoln Mercury Reprogramming Kits The first 2 are for the Tugger and HD2.
Old May 2, 2008 | 07:45 AM
slk133's Avatar
slk133
Never opened a tranny before, but when ordered was hoping I could do this myself to save money. Saw in the box of goddies a drill bit and other small pieces and found the instructuions a little different to follow. I do not want to pull the tranny, I thought with this kit you do not have to, but noticed a big retaining clip. I will also check the transgo web site also.
Old May 2, 2008 | 08:00 AM
Technitom's Avatar
Technitom
Veteran: Navy
<jk> the big retaining clip is to hold the shop rag around your wrist to keep the fluid from running down your arm and into your armpit...LOL
Old May 2, 2008 | 08:04 AM
mueckster's Avatar
mueckster
The HD2 kit is very similar to the Tugger. Just doesn't include the parts to modify the front pump, which requires removal to do. I did all these mod while rebuilding/ upgrading the trans. There may be a few other parts included that won't be used unless you have the trans apart. Some mods to the valve bodies are model specific.
Old May 2, 2008 | 04:50 PM
slk133's Avatar
slk133
Thanks for the help gonna look at it tonight...........
Old May 2, 2008 | 04:55 PM
crum71's Avatar
crum71
1/8 mile Oval Track
Theres that box of confusion that I have still riding around in the back seat of my truck....ugh, just haven't got around to giving it a try, I figure,its in my truck,just not installed yet. Oh well
Old May 2, 2008 | 05:08 PM
slk133's Avatar
slk133
Well thats close least it is in the truck. Ya the box scares me, it was ok till I saw drill bits....
Old May 2, 2008 | 07:03 PM
Tenn01PSD350
Folks, I will try to do the writeup, or something similar here tonight after I wrap up a few loose ends. Stupid rain. The video is good, but does not even cover the plate or the solenoid pack. I will check back. You really can do this yourself. BTW, my kit has the or at least some front pump mods. I did not do those.
Old May 2, 2008 | 08:35 PM
Izzy351's Avatar
Izzy351
Guys....
Just get started. The instructions aren't actually all that bad if you follow it word for word. The only major SNAFU that I *almost* jacked up and Mike did was the procedure for pulling the solenoid pack out. It doesn't tell you to pull the connector from up top. I started to pry on it after pulling all the screws and stopped when I felt there MUST be something I was missing. I just put the screws back in and left it. Mike can go into more details because he has pics, but it really isn't all that bad. I put it off for months -- I would do it in a heartbeat now. My only advice is to do one valve at a time when you pull the accumulator VB out. It would be way too easy to get springs & parts mixed up if you tear the whole thing apart and try to do them all at once. When you do one at a time, it's really obvious what springs go where.
I did the main VB mods, and the accumulator mods and that's it. I didn't pull the tranny to do the pump/TC lockup mods and don't regret it at all. It shifts nice & firm -- WAY better than before!!
Old May 2, 2008 | 08:50 PM
Tenn01PSD350
Thanks Joe, I am back. I need to start by scanning the instructions. This may take a while because I need to edit in some text too, then save. I already have all the pics I am going to have so the instructions are about it.
BTW, the only reason your solenoid pack didn't come out is because you are a girly man.
Old May 2, 2008 | 08:59 PM
Izzy351's Avatar
Izzy351
You suck, Mike.
Old May 2, 2008 | 09:22 PM
Tenn01PSD350
Originally Posted by Izzy351
You suck, Mike.
Sorry bout that. You just don't know if there was something to do there. Now after I do the writeup, you may need to weigh in on the main VB stuff because I didn't feel the need to touch mine so left it alone. I had to rescan the instructions cause the res was way to low. Damit.
