water separator leaking
Old May 1, 2008 | 02:00 PM
tpolley's Avatar
tpolley
i just put a new fuel filter on my 92 7.3idi. i replaced the big o-ring between the filter and the water separator and put a dab of oil on it like the destructions said. now the separator leaks at the drain valve. it just seeps when it's sitting but when the truck is running it drips pretty good. is there anything i may need to know before i take it back off to check it out?
Old May 1, 2008 | 07:58 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Is the drain valve closed completely?
Old May 2, 2008 | 08:46 AM
tpolley's Avatar
tpolley
yeah, it's closed all the way. also, i examined it closer last night and it turns out it was water from the the a/c condencer i saw dripping under the truck but the separator is still seeping a little when the truck is running. it's not as bad as i thought. it could have been seeping before i replaced the filter, i dunno. is there an o-ring on the valve that can be replaced? i looked at oreilly's web site and i can't find the separator.
Old May 2, 2008 | 01:09 PM
rmalottwtes30's Avatar
rmalottwtes30
The water separator is a FORD item, and runs around $300 bucks.
Old May 2, 2008 | 08:32 PM
Joetravelall's Avatar
Joetravelall
Sorry to correct you, but the fuel filter base is a Navastar item repackaged by Ford. I paid $130.00 for one 12 months ago from Ford it was special order. They do make a seal kit that replaces that valve seals. Mine was leaking from the Srader valve so I just got a new base. I think it was the Ultra Low Sulfer Diesel (ULSD) that took out most of my rubber in my 92 F 250 XLT 4X4. The injector return lines started and the day I replaced them I also replaced the fuel filter and the base started leaking then.
Old May 2, 2008 | 08:37 PM
6.9 Diesel's Avatar
6.9 Diesel
stupid question, the "valvestem" on the side of the fuel filter housing, is that there to drain water in the fuel, or relieve pressure from the fuel system?
Old May 2, 2008 | 10:19 PM
Dave Sponaugle
Check fuel pressure and let air out of the filter are the main uses.
Old May 3, 2008 | 03:39 AM
Joetravelall
My question is what is the purpose of the schrader valve on the base for? It is just next to the drain valve. Sorry about my spelling of schrader on my first post.
Old May 3, 2008 | 07:33 AM
6.9 Diesel's Avatar
6.9 Diesel
ok so if the "valvestem" is used to check pressure, and relieve air from the fuel system, can it be used to bleed when reinstaling a new fuel filter, or changing fuel injectors, or do you have to do it at the the injector couplings only. i know stupid question but its been an unsolved question ive had. thank you all for all your help
Dieselamour
Virginia Chapter
Jul 30, 2012 06:44 PM
EMD_DRIVER
Jul 29, 2012 09:07 PM
86.9
Apr 22, 2010 09:25 AM
Tom D
Sep 14, 2008 03:54 PM
ddb
Sep 27, 2005 03:27 PM
