390 to 460
Old Apr 30, 2008 | 11:32 PM
AzSlugger's Avatar
AzSlugger
390 to 460
I have a 73 with a 390 how hard would it be to go to a 460 or would it behoove me to go smaller say 302? also it has a c6 trans
Old May 1, 2008 | 12:27 AM
RA0429262's Avatar
RA0429262
Banned
Take your 390 and use 428 crank and rods, plus a few other tidbits and shazammmm.
Old May 1, 2008 | 01:01 AM
AzSlugger's Avatar
AzSlugger
Thats what I figured although fuel consumption is a concern of mine so if i do anything I'll probably just stick with the 390
Old May 1, 2008 | 01:09 AM
65f100_352's Avatar
65f100_352
By no means are you going to get better gas millage with a 460. What will help a little, key word little, is a 4bbl and intake, and free flowing exhaust.
Old May 19, 2008 | 11:37 PM
bigblacktruc's Avatar
bigblacktruc
if gas mileage is your main concern.
go and buy a ranger with a 3.0l v6 in it
Old May 20, 2008 | 12:13 AM
AzSlugger's Avatar
AzSlugger
But then I wont be able to cart around my camper
Old May 20, 2008 | 12:54 AM
85e150's Avatar
85e150
What condition is your 390? Good dual exhaust at least, with crossover pipe just behind the trans. Headers are preferred. You can do the 4bbl but what fun is that if you run around on the primaries?
You thinking of a rebuild?
If you are carting something heavy, you are going to flog the 302 and it will be almost a thirsty and somewhat to very unsatisfying.
Your best bet for economy is pumping up the tires, tune up the engine and slow down.
Old May 20, 2008 | 06:21 PM
69-highboy's Avatar
69-highboy
Face it, you're married to that FE without a donor vehicle to steal parts from for your 460 transplant. On the positive side, your 390 doesn't have to be a slouch -and won't be with a few of the right parts. A stated earlier, a free-flowing exhaust, 4bbl carb and a prudent right foot would be a good start. I can see no reason why such a combination shouldn't net you 13 to 14mpg.
Old May 20, 2008 | 06:30 PM
85e150's Avatar
85e150
This is an F100, correct?
Your 9 inch swaps out in less than two hours, including beer run.
Check your ratio.
Dear Old Dad's had 3.25s.
Since you are carrying a hefty load from time to time, you probably shouldn't go below 3.0s, but first, what ratio do you have?
Old May 28, 2008 | 04:48 PM
AzSlugger's Avatar
AzSlugger
I found the tag on the rear 357 was this a ratio that was common?
Old May 28, 2008 | 04:57 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No such thing as 357, the tag from this vintage vehicle will either have WDM- something on it, D3TA-something, or for example 3L50 if LS, or 350 if not.
What is the AXLE code on the Warranty Plate?
It'll be either two or three digits.
1973/76 F100 & 1975/76 F150 (the usual) 9" ratios: 3.00-1 / 3.25-1 / 3.50-1 / 3.73-1
Old Jun 2, 2008 | 05:38 PM
AzSlugger's Avatar
AzSlugger
I will look later on tonight. It is very hot outside right now and I just got home from work.
Killgore
21
Jul 12, 2013 11:12 AM
Homelessduck
May 2, 2007 10:01 AM
otto
Feb 8, 2002 06:12 PM
chilly460
58
Sep 13, 2001 06:57 PM
usmcdi
Sep 25, 2000 07:46 AM
