Differentiate 351W or C?
Old Jul 31, 2000 | 10:55 PM
chichi's Avatar
chichi
How exactly can you tell the difference between the 351 Winsors and the Clevelands? Do you know about how much HP each one produces stock? I'd appreciate any help here.....
Old Aug 1, 2000 | 09:16 AM
gypsybill's Avatar
gypsybill
Quickest way I tell the difference in the W and C is the waterneck on the W comes out of the intake manifold and out of the block on the C.. lots of other ways (like spread between the heads, etc) but this is a quick visual.
Horsepower is relative to the year models of the engines, 2V or 4V, application, etc.
Old Jul 4, 2001 | 02:05 PM
FastPony's Avatar
FastPony
351w have 6 valve cover bolts, clevlands have 8 (I think).
Old Jul 10, 2001 | 09:28 PM
joereidattvecdotnet's Avatar
joereidattvecdotnet
This an easy way.. The 351W has fuel pump bolts that horizonal and the Clevleand has vertical bolts. 351W fuel pump bolts on like a 289 and 302, and the Cleveland is like a 400 or 351M ..
Old Jul 11, 2001 | 08:21 PM
dpattonfl's Avatar
dpattonfl
[font size="1" color="#FF0000"]LAST EDITED ON 11-Jul-01 AT 09:23 PM (EST)[/font][p]Look at the spark plugs.
The Windsor heads use the big 13/16" plugs.
The Cleveland heads use the smaller 5/8" plugs.
The heads will NOT interchange.
I don't know what the numbers are, but the Cleveland produced more HorsePower and Torque.
Old Jul 19, 2001 | 12:15 AM
truckkiller's Avatar
truckkiller
Do not listen to the above comments, windsor is a small block with 5/8 plugs and a cleveland is a BIG block with 13/16 plugs and a wider intake manifold
Steve, and Jamie,
Old Jul 19, 2001 | 12:23 AM
Franklin2's Avatar
Franklin2
Truckkiller, I dare you to post that in the 351c/351m/400 forum.
Old Jul 19, 2001 | 02:29 PM
lvstang's Avatar
lvstang
[font size="1" color="#FF0000"]LAST EDITED ON 19-Jul-01 AT 03:32 PM (EST)[/font][p]LMAO @ the last few posts. The heads WILL interchange(slight mods needed) and the C/M IS NOT a big block!!!!
Considering there are at least 3 INSTANT visual clues to tell the C/M apart from the W, pulling spark plugs seems a little silly!!!
Old Jul 28, 2001 | 08:46 AM
dpattonfl's Avatar
dpattonfl
You don't need to pull the plugs. Just look at them to determine which size socket you would need.
If you had to pull them out to determine which size socket you needed to pull them out, then how would you ever....??????????
Old Jul 28, 2001 | 05:05 PM
lvstang's Avatar
lvstang
Fair enough. But why pull plug wires when you're instantly/easily able to visually tell the difference between the two motors? At least you didn't defend your head interchangeability comment. LOL!!
Old Jul 29, 2001 | 11:14 AM
southernman1172's Avatar
southernman1172
The easiest and quickest way, without breaking out any tools, is to lift the hood and look at the thermostat housing (where the top radiator hose goes to the motor). The Windsor engines (300, 302, and 351) have the housing on the VERTICAL FRONT, while the Cleveland engines (351C, 351M, and 400) have it on the HORIZONTAL TOP. And by the way, the Windsors are small blocks, the Clevelands are M-blocks, and the 429/460 are Big Blocks.
Old Jul 29, 2001 | 11:03 PM
lvstang's Avatar
lvstang
Yea, just as easy as looking which way the fuel pump bolts mount, right??? Or counting valve cover bolts???
Will disagree on your big block/M/small block ID, though. The M's are different than the Clevelands simply because of deck height and bell housing bolt pattern. So to to call Clevelands M blocks is incorrect. The reason I consider 302's, Windsors, Clevelands and M's small blocks is one simple reason: They all share the small block bore spacing and the head bolt pattern with each other. While the M's are physically NEAR a big block in size, so is a 4.6 DOHC, and at 281 inches nobody would EVER call that a big block!!!
If you want to call M's "modified Clevelands" I can see that, since the Cleveland was before the M. But to say the Cleveland is an M block doesn't make sense IMHO. But they all are small blocks to most because of the head interchangability.
Old Jul 30, 2001 | 12:34 PM
southernman1172
